All Part Number Request Go Here
Old Oct 20, 2016 | 02:35 PM
  #4381
cerevo's Avatar
Does anyone know what the part number for the nut that bolts the power steering high pressure line to the power steering pump output is?
Also I think there is a banjo bolt that goes to the rack on that same line that I am missing. I have looked for it in Evoscan and I can't find it.
Old Oct 20, 2016 | 03:17 PM
  #4382
dr_latino999's Avatar
Veteran: Army
MF430727 - Nut P/S Oil Line Jam, 12
MF450407 - Washer, P/S Oil Line Spring, 12
Old Oct 21, 2016 | 08:01 AM
  #4383
Veteran: Army
Forgot the banjo bolt
MR554636 - Eyebolt, P/S Oil Line
Old Oct 21, 2016 | 09:28 PM
  #4384
evo8vz's Avatar
need 5 speed
oem evo 9 input shaft, oem evo 9 1st gear, 3rd gear synchro, 3-4 gear fork
Old Oct 22, 2016 | 05:17 AM
  #4385
Mitsubishi
MN107627
SHAFT,M/T INPUT
Mitsubishi
MR980814
GEAR,M/T OUTPUT SHAFT 1ST
Mitsubishi
MD770348
RING AS,M/T 3RD SPD (syncro)
Mitsubishi
MD746338
FORK,M/T GEARSHIFT O/D (3rd & 4th)
I PM'd you some info
Old Oct 25, 2016 | 02:34 PM
  #4386
RALLI1's Avatar
Part number for 09 ralliart exhaust manifold.... since there's appparently 3 different ones
Old Oct 25, 2016 | 05:02 PM
  #4387
I tried & failed. The site I use could not identify the Ralliart over EVo. The non CT9A's are not in my skill set
Old Oct 27, 2016 | 09:33 AM
  #4388
evo8vz's Avatar
evo 8 4th gear synchro?
Old Oct 27, 2016 | 09:53 AM
  #4389
I used a 2004 EvO as a search parameter & coming up w/this:
Mitsubishi
MD770054 / HUB,M/T 3RD & 4TH SYNC
Please double check
Old Oct 27, 2016 | 09:56 AM
  #4390
evo8vz's Avatar
hello the synchro not the hub
3rd gear and 4th are different synchro
Old Oct 27, 2016 | 10:12 AM
  #4391
Just sent you a PM
Old Nov 1, 2016 | 09:54 PM
  #4392
garrettk14's Avatar
Originally Posted by Raptord
56202L = MR407890 (left bracket)
56202R = MR407891 (right bracket)
54992 = MA431825 (clips to hold the lines. Looks like you need 4 in total)
Any change I could get some help on the part numbers for the following:
front right brake line (56267R I Think in the picture)
The clips labeled A, B, C, D and E
The firewall insulation blanket
Thanks!
Old Nov 2, 2016 | 06:04 AM
  #4393
Thanks!
Couldnt quite nail down the brake line but here are the others:
Please double check before ordering
Firewall insulator = Mitsubishi MR972468
clip A MR129462
clip B MB895797
clip C MB344693
clip D MR205046
Old Nov 2, 2016 | 07:57 AM
  #4394
Mitsubishi
MR493302 (item no. 56267R)
Old Nov 11, 2016 | 06:14 AM
  #4395
Bump/ We are available if you need part no.s researched
