All Part Number Request Go Here
Old Dec 7, 2016 | 10:35 AM
  #4411
CJEvoIX's Avatar
Life saver! Thank you!
Old Dec 11, 2016 | 09:36 PM
  #4412
CJEvoIX's Avatar
Anyone has a clue on the parts needed for a compete rebuild for an E9 front bumper?
Old Dec 12, 2016 | 06:14 AM
  #4413
Just PM'd you some info
Old Jan 4, 2017 | 01:23 PM
  #4414
shesfelicia16's Avatar
Ralliart Rear Diff Cover
Need the OEMpart number for the rear diff cover for a 09 ralliart or a few places to hunt for a replacement cover of part number can't be provided. Thanks
Old Jan 16, 2017 | 01:29 PM
  #4415
pushdragon's Avatar
Transfer Assembly - Tapered Roller Bearing Part Number Needed
Oh i tried and tried, now i beg for help.
In search of the part number for the tapered roller bearing (needle bearing) pictured on the left side of this front dif. It seperates the dif and t-case for 2oo3 evo usdm.
Thanks my best friends. Over n out
Old Jan 17, 2017 | 09:59 AM
  #4416
EvoooB's Avatar
Hello guys, I'm looking for the EVAP system hardline that runs underneath the car and pops up in the engine bay. It's approx 9-10' long and I believe is a 8mm tube... it runs under the car in the same area as the fuel feed and return tubes. I need this bad! Thanks for any info you can provide!
Old Jan 17, 2017 | 10:22 AM
  #4417
Are you referring to a line that runs from the charcoal filter box in the drivers rear? Wasnt sure what you meant by EVAP
Old Jan 17, 2017 | 10:26 AM
  #4418
Heres an exploded view of the 7/8/9 rear diff. Not sure if it matches your picture. Item 34004 looks like of more of cartridge bearing
Old Jan 17, 2017 | 01:30 PM
  #4419
deylag's Avatar
Originally Posted by shesfelicia16
need the oempart number for the rear diff cover for a 09 ralliart or a few places to hunt for a replacement cover of part number can't be provided. Thanks
3501a350
Old Jan 17, 2017 | 01:45 PM
  #4420
deylag's Avatar
This is what I found
MR993691
Old Jan 18, 2017 | 05:41 AM
  #4421
EvoooB's Avatar
Yes sir. The steel hardline I'm referring to hooks up to the small rubber hose coming out of the charcoal filter box in the rear, and runs to the front of the vehicle and the steel hardline pops up in the engine bay right near the fuel feed/return lines. If you look in the back right hand corner of the engine compartment there are 3 steel tubes that come up together, fuel feed, fuel return and the steel hardline for the fuel vapor from the charcoal filter box which is the one I need. Thank you!
Old Jan 18, 2017 | 06:14 AM
  #4422
deylag called out a part no. but not sure if thats what youre looking for
Here are a 2 schematics. Is it item no. 05622?
Old Jan 18, 2017 | 06:39 AM
  #4423
EvoooB's Avatar
I think that is the one... its kind of hard to tell by that 1st drawing. If you look at the 2nd drawing, I know for a fact the steel line I need connects to hose P/N 05617B if this helps at all?
Old Jan 18, 2017 | 06:54 AM
  #4424
EvoooB's Avatar
Yes, thats that correct P/N you were looking at... 05622 which is MR993691. Is that part available ot order? Thanks!
Old Jan 18, 2017 | 07:29 AM
  #4425
item no. 05622 shows to be MR571324 (Deylag found this no. MR993691). I tried looking both no.s up & dont see any U.S Mitsu dealers noting that part no.
Might be best just to call this into the dealer to confirm
