All Part Number Request Go Here
^That might be the return line...either way see here for diagram and part number for both feed and return...
https://stmtuned.com/collections/evo...hose-oem-evo-8
https://stmtuned.com/collections/evo...-oem-evo-7-8-9
On the side of the key cylinder housing there is a light brown ( electrical switch ?) thats held by two screws and the wires lead to a connector that splits to the electrical key switch and back up to the key ring that lights up. Mine is broke and the alarm chimes like if the key was still in the ignition. Is there a part number for that harness?
It looks like this
It looks like this
It looks like this
It looks like this
Can someone please let me know the part number for the vacuum line "kit" that connects to the wastegate actuator, j pipe, intake inlet tube, and factory boost control solenoid. Thanks in advance.
Looking to replace my serpentine belt. I am seeing some different part numbers...
1st from stm website has part number MIT-MN158794
https://stmtuned.com/collections/evo...7-8-9-with-a-c
2nd from extremepsi with part number MIT-MZ690266
https://www.extremepsi.com/store/pro...roductid=22696
3rd from maperformance same part number as extremepsi MIT MZ690266
https://www.maperformance.com/produc...lution-evo-8-9
So stm has a different part number but a higher price compared to extremepsi/map. Will the extremepsi/map one be fine or is there some benefit/reason to get the one stm has?
