All Part Number Request Go Here
Old Jan 18, 2006 | 07:51 AM
  #946
nbpal4000's Avatar
can anyone help me to provide the part number for Fuel Tank Drain Plug???????
thanks!!!!!!! nm guys..I found it..
its 1715A135..
its backordered..damn it..
Old Jan 20, 2006 | 06:35 PM
  #947
jlperez3's Avatar
Passenger side engine support bracket, passenger side engine mount, this is the one that mounts to the block and has the threads for the timing belt tensioner tool. Also looking for the metal timing belt cover (front of the engine with the rubber plug for the tensioner tool) with 2 10mm mounting bolts, mounts to the block behind the exhaust cam sprocket...
And also want to see where to buy MD998752-01 Tension pulley wrench.
Old Jan 21, 2006 | 09:51 AM
  #948
ScoobyBoy2's Avatar
can anyone give me the part number to the entire sunglasses holder with the lights. and an approximate cost...thank you
ian
Old Jan 22, 2006 | 01:52 AM
  #949
Pesebo's Avatar
High-mounted stoplight ---> MR632020
Old Jan 22, 2006 | 11:23 AM
  #950
jlperez3's Avatar
Items 29 and 33
Anyone help...
Old Jan 22, 2006 | 12:02 PM
  #951
matej's Avatar
Hi
can anybody suply me number for front bumper cover in black color for EUROPEAN model?!
Is that cover the same in USA and EU version, because I had problems with assembly EU bumper on USA body??
M
Old Jan 24, 2006 | 10:50 AM
  #952
EVONation's Avatar
ANYONE with the OEM Tail Light assembly part number? I've been searthing this thread and NO luck... PLEASE PLEASE HELP...
Old Jan 24, 2006 | 02:12 PM
  #953
readrs13's Avatar
need part numbers for vacuum lines running from turbo and wastegate to tee to boost solenoid to intake and the one from bodv to intake
thanks
Old Feb 1, 2006 | 05:09 PM
  #954
EvoRicer's Avatar
Anyone have the Part Number to the Airbox Bracket?
Old Feb 2, 2006 | 07:49 AM
  #955
Alacris's Avatar
I found the part numbers for all the door handles and front bumper cover for the Evo VIII, but . . .
Does anyone have the part number for the rear bumper cover in yellow? I need it for an insurance estimate (rear ender damage).
Thanks,
AC
Old Feb 3, 2006 | 05:12 AM
  #956
justchil's Avatar
I need the part# for the wheel well plastic on the passenger side.
I found this but it's for the driver side:
2003 lancer evo 8 inner fender wheel well plastic driver side front
MR954175 - Shield Kit, Splash, Front LH
Old Feb 3, 2006 | 03:31 PM
  #957
Trueno86's Avatar
I need the part# for the red (+) battery plastic terminal cover please. Thanks!
Old Feb 8, 2006 | 04:03 PM
  #958
hcj's Avatar
hcj
sorry
Old Feb 8, 2006 | 07:54 PM
  #959
evo8dad's Avatar
Looking for the part number for the RS and/or MR LSD, if it is available as a seperate item.
Old Feb 17, 2006 | 06:23 AM
  #960
PapitoEVO8's Avatar
Looking for the part number for the hose (big hose)in between the upper ic pipe and the stock by-pass valve (BOV) and also the small hose that has the restrictor pill that joins a plastic T for the stock boost controller. Thanks.
