All Part Number Request Go Here
Old Aug 18, 2006 | 03:53 PM
  #1186
Spins4's Avatar
Originally Posted by DruMMinStUd06
just the washer or the plug also?
That is just the crush washer on the drain plug. No need to replace your drain plug unless its stripped. If it is, thats MD050316.
Old Aug 18, 2006 | 05:52 PM
  #1187
Ro's Avatar
Ro
what are the part numbers for fuel pressure solenoid and evaporative emission purge solenoid?
i need those two solenoids to pass the emissions inspection and currently they are missing from my car.
Thanks!
Old Aug 21, 2006 | 11:37 AM
  #1188
EVOLUTION/RC51's Avatar
Would anyone possibly have the part number of these two Bump Stops below:
Thanks.
Old Aug 21, 2006 | 11:49 AM
  #1189
MBaran's Avatar
Thanks.
I believe they are MR473003. Someone may want to double check, since MR288769 also looks like them, but I think 769 are the two dampers on the sides of the hood not the front.
Old Aug 21, 2006 | 01:21 PM
  #1190
Spins4's Avatar
Actually those are the MR288769..the 003's are the ones further up.
Old Aug 22, 2006 | 06:57 AM
  #1191
travman's Avatar
I searched this whole topic and there was never an answer on the door panels for the ssl evo's. I would like to know what that is, I just bought an 06 and I dont like the cloth panels. I want to go back to the ssl panels that were in my 04, they made the car so much nicer and were a lot more comfortable I thought?
Im looking for part numbers on both L+R front and L+R rear......
Old Aug 22, 2006 | 01:17 PM
  #1192
Spins4's Avatar
If you happen to have a vin to an EVO with the ssl package I can check for you. But with CAPS, it just gives production breaks and no description.
Old Aug 22, 2006 | 01:30 PM
  #1193
MBaran's Avatar
CAPS is pretty picky with EVO vins. I havent found one vin that works in CAPS for an evo.
Old Aug 22, 2006 | 09:31 PM
  #1194
Ultimateone's Avatar
I need the plastic piece of the boost solenoid, in which has 2 vacuum ports, one side broke right off.
Thanks
Old Aug 23, 2006 | 05:43 AM
  #1195
Spins4's Avatar
How old is your version of CAPS? I know my vin works in my CAPS (then again I would hope so being a dealership), but mines an 03 GSR.. won't do him any good to use mine.
Old Aug 23, 2006 | 05:44 AM
  #1196
Spins4's Avatar
Thanks
MN143213
Old Aug 23, 2006 | 08:37 AM
  #1197
MBaran's Avatar
mine is 3.41 which was produced around Oct. 04 and has parts going through the 05MR.
But even if I plugin an 04 SSL vin, I get not found.
I think 03 vins seem to work okay on mine..
Old Aug 23, 2006 | 09:23 AM
  #1198
Spins4's Avatar
Ya CAPS can do crap like that. But you figure, Mitsu releases me a new one I think every 6 months or so, so you know things are constantly changing. Grab me a vin if you can and I'll see what mine does.
Old Aug 23, 2006 | 01:55 PM
  #1199
20psiMR's Avatar
Anyone able to give me more info on these part numbers? They are on my invoice from service, had a 5th gear grind and this is what they are replacing. Im wondering if its pretty much all the internals...
MN132429
MN132403
MN132411
MN132421
MN132407
MN132419
MN132415
VIN is JA3AH86C86UO41800 in case you need it. For MR 6 speed tranny.
Old Aug 23, 2006 | 02:37 PM
  #1200
MBaran's Avatar
yeah, i wish someone would get us here on the internet an updated copy of caps with some evo 9 stuff in it. Too bad the DSM group that used to keep getting it has seemingly dissapeared...
