dynamat under the car for exhaust droning?
Old Feb 27, 2005 | 10:49 AM
Derek888's Avatar
Any idea if it helps and how much is needed to help the droning?
Old Feb 27, 2005 | 10:54 AM
tcarretti's Avatar
I have a 2004 EVO RS which came with absolutely no sound deadening in it. I ended up putting dynomat Extreme in the trunk to basically cover the whole bottom pan and a bit along where the trunk latch is.
It helped a bit, but I think the best way would be to do the floorboard as well since the majority of exhaust/engine drone comes from there.
It wouldn't be cheap though. Good luck if you decide to do it.
Tony
Old Feb 27, 2005 | 11:05 AM
Derek888's Avatar
i saw someone do it under the car right above the pipe. not even sure if it will stick well and fall off. wouldnt the heat melt the material?
Old Feb 27, 2005 | 11:08 AM
tcarretti's Avatar
I would think that applying it that close to the exhaust would not be good. It's like a rubber material with foil over it. It's pretty gooey all by itself so get it hot and who knows what would happen. You could always try a small piece and give it a shot just to test adhesion. You'd really have to clean off the area where you were going to apply it though.
Old Feb 27, 2005 | 11:11 AM
housedj's Avatar
Dynamat actually suggests that heat will help the adhesion process when applying. i can't say that being near the exhaust would help that much & a bulk pack of the Extreme is like $200!!! the evo is just a thin metal car. there is not much you can do. you can try it in a little area & see if that helps, or you may have to run dynamat the entire length of the exhaust on the inside of the cabin.
Old Feb 27, 2005 | 11:15 AM
k.lowe's Avatar
+1
Old Feb 27, 2005 | 11:16 AM
electricevo's Avatar
Housedj is right, i think the cost to do that would far outweigh the results. Acheaper alternative would be turning the radio up on highway trips
Old Feb 27, 2005 | 11:19 AM
evolution mr'd's Avatar
another way is to pull out all of the carpet and seats and cover everything, and have it rhino lined then replace everything. works really well! or you couls leave out the carpet then when your floor gets dirty hit it with a wet sponge.
Old Feb 27, 2005 | 11:27 AM
05-EVO-GSR's Avatar
Try putting on a cat and changing your exhaust system.
Old Feb 27, 2005 | 11:44 AM
koolade9's Avatar
low frequencies are omnidirectional, to keep it out, you'll need to do alot of different types of sound deadening. dynamat is just mass loading, it does help, but only for higher frequencies, as is reduces/eliminates resonation. to kill the lower notes, you'll need a filler type of sound deadening, like fiberglas, or carpet padding, the thicker the better. I've sound deadened my past 5 cars, and i've used all different methods. almost all of them require adding weight to the car.
i haven't started on the evo yet... when i do, I can let you guys know what worked best on my car.
short answer, putting just once peice of dynamat by the exhaust, or running it down the center... will do nothing but make the car heavier. it's gotta be a total strategy...
i'll work on it
Old Feb 27, 2005 | 02:09 PM
BMan's Avatar
If your exhaust is so loud it bothers you, just think how your neighbors feel about it.
Old Feb 27, 2005 | 09:32 PM
Derek888's Avatar
its the droning that makes the car kinda of rattle...dont mind the sound just the vibration
Old Feb 27, 2005 | 09:35 PM
hanahawaiian's Avatar
lucky me.. im deaf.. hee hee.. i gotta love feel power from car.. I had Nova with 327 stroker V8.. it alot of fun..
Old Feb 27, 2005 | 09:44 PM
UT_Evo's Avatar
Yeah, and outweigh, well, it'd just outweigh too... it's not light, I have it in my trunk and parts in my front doors, the trunk auto closes now, with little effort ... I say buy a better exhaust, or crank up the radio... but if you decide to do it, you can check at stereo shops and see if they have some scraps, I got all mine for free but it is in weird shapes
Old Feb 27, 2005 | 09:54 PM
Jovani's Avatar
Well I just installed a hks hi power catback and my car rattles too, but when i took it to the shop that installed it for me they put it up on the left and had my car idling, and they noticed it was coming from the gas tank shield. They advised that I should put some Dynamat on it. But i didnt, because I dont like the idea of having dynomat on the bottom of my car. Seems like a cover up fix to me.
