top of 3rd jolt
Old Mar 4, 2005 | 04:35 PM
bigjhoney's Avatar
top of 3rd jolt
Had the battery disconnected for 2 days due to getting some work done. After I hooked it back up I took it for a ride. First 3rd gear pull- at about 5500 rpms car jolted and like shut off for half a sec. then continued as normal. Did it once again after. Brough it back to my house and let it run for like 10-15 min. Took it for another ride and it didnt do it twice in a row. Went out half an hour ago did it first time, didnt do it second time. Would this have anything to do with the ecu resetting itself?
BTW the car is bone stock.
Old Mar 4, 2005 | 04:36 PM
evo_whiplash's Avatar
Sounds like it could be boost cut.
EDIT: Just saw that it was stock. Did you let it idle for 5-10 min. after you started it up the first time? Have you checked all the electrical connections?
Old Mar 4, 2005 | 04:44 PM
j8's Avatar
j8
Check you DV valve. I had this same problem a while back. It ended up being that the DV valve housing had cracked. It started off every once and awhile and then became more consistant until I located the problem.
Old Mar 4, 2005 | 04:48 PM
bigjhoney's Avatar
thanks
Old Mar 4, 2005 | 05:00 PM
bigjhoney's Avatar
yea all the connections are fine.
Old Mar 4, 2005 | 05:43 PM
bigjhoney's Avatar
Just got back. Took the car for a ride again, top of third gear it jolted the hardest it had so far, and the service engine soon light lit up. I just got the car back from the body shop, got a new front mount, radiator, and a couple other parts replaced. What could this be? thanks
Old Mar 4, 2005 | 06:12 PM
bad03evo's Avatar
man that sucks, wish i could help!
Old Mar 4, 2005 | 06:13 PM
can you have the code pulled?
Old Mar 4, 2005 | 06:21 PM
bigjhoney's Avatar
Im about to go up to walmart and buy a code reader, cause im not in the mood to wait, 3 weeks without the car, ive waitied enough to deal with this bs now.
Old Mar 4, 2005 | 07:32 PM
bigjhoney's Avatar
nope they dont sell them no more, anyone else have any ideas..?? thanks
Old Mar 4, 2005 | 07:33 PM
Go to an auto parts store. Most will read them for free.
Old Mar 4, 2005 | 07:34 PM
bigjhoney's Avatar
yea I was going to go to autozone first thing tommorrow morning, everything closed right now.
Old Mar 4, 2005 | 07:42 PM
j8's Avatar
j8
What mods do you have to the car? It could be fuel or boost cut as mentioned earlier.
Old Mar 4, 2005 | 07:43 PM
bigjhoney's Avatar
bone stock
Old Mar 4, 2005 | 08:38 PM
bigjhoney's Avatar
I was reading someother threads and came to somewhat of a conclusion of what it could be. p0300 misfire, because from what i read it said that if the car has been sitting for a while( 2 1/2 weeks) it is a possibility. Plus on how they explained the car jolting/sputtering, sounds alot like what I was expeirencing. Any body think this is a possibility? thanks
