boost cut problem
Old Mar 13, 2005 | 08:11 PM
bigjhoney's Avatar
Angry boost cut problem
Ive heard from a member this could be caused by cold weather...anyone second that? I got my car back from the body shop about 2 weeks ago and it was hitting boost cut like crazy for a couple days throwing the po234 overboost code. Got it checked out, made sure all hoses were tight and it was fine for about a week and a half and tonight out of no where i hit boost cut in 3rd then about 5 min later in 4th. Can anyone help me out? thanks
Old Mar 13, 2005 | 08:16 PM
MitsuJoe's Avatar
any mods?
Old Mar 13, 2005 | 08:17 PM
bigjhoney's Avatar
Only mod i have is an hks drop in filter.
Old Mar 13, 2005 | 08:40 PM
bad03evo's Avatar
same thing was happening to me but i got mods so I have no idea.
Old Mar 13, 2005 | 08:42 PM
plokivos's Avatar
boost cut's at 24 psi est. but if you're only peaking, you shouldn't hit the boost cut.
are you sure you're not knocking or running lean?
Old Mar 13, 2005 | 08:44 PM
Tim@AMSperformance's Avatar
How much boost are you running? If you have a boost controller you can lower the boost and it will fix it. Other than that cold weather will effect fuel cut because the air is less dense
Old Mar 13, 2005 | 08:49 PM
bigjhoney's Avatar
I dont see how I would, havent modified the car at all.
Old Mar 13, 2005 | 08:51 PM
GIsnickers's Avatar
Have you reset the ECU?
Old Mar 13, 2005 | 09:04 PM
bigjhoney's Avatar
yep twice, not since it happened tonight though.
Old Mar 13, 2005 | 09:07 PM
voidhawk's Avatar
sounds like you got some crappy gas maybe?
Old Mar 13, 2005 | 09:11 PM
bigjhoney's Avatar
I dont know, i put sunoco 94 octane in it, but the tank was pretty low tonight but i have filled up $10 worth 3 times this week. Would higher octane have anything to do with this?
Old Mar 13, 2005 | 09:14 PM
voidhawk's Avatar
higher octane would be better, not worse. Try a different gas station maybe
Old Mar 14, 2005 | 04:15 AM
bigjhoney's Avatar
bump
Old Mar 14, 2005 | 05:32 AM
the-moss's Avatar
If one of the vacuum lines running to the boost solenoid has come off or has a hole in it then you will overboost and probably hit fuel cut.
Do you have a boost gauge to verify the boost? Can you describe what it feels like when it happens? Hitting fuel cut is pretty violent.
Also if you have no mods then isn't your car still under warranty? Let the dealer figure out if something is wrong.
Old Mar 14, 2005 | 06:46 AM
bigjhoney's Avatar
usually at the top of third around 5500-6000 rpms it will just feel like it hit a wall, and sometimes it will happend at the top of 4th gear
