272's How much fuel to add?
Old Mar 16, 2005 | 01:58 PM
ThEHiTMaN's Avatar
I have a Road tuned flash on my ECU. I am looking to get HKS 272 cams.... Any ideas on how much fuel should be added with my AFC. I read some where that Buschur added 15% for the new cams... Thanks
I am running 21 psi, Flash, AFC II, 3" turbo back no cat, Walbro 255, and MR DV.
Old Mar 25, 2005 | 01:35 PM
ThEHiTMaN's Avatar
Maybe a better question is. Would the car be safe to drive around for a while until I can get the ecu flashed again?
Old Mar 25, 2005 | 01:37 PM
EvilDylan's Avatar
should be.
take it easy though.
Old Mar 25, 2005 | 03:26 PM
netmand's Avatar
yeah if previous flash took out the fuel cut then you need to be careful.
Old Mar 25, 2005 | 03:28 PM
en1gma19's Avatar
Just don't drive it hard until it's retuned and you should be fine.
Old Mar 25, 2005 | 04:12 PM
silverofs's Avatar
do you remember your hz on your afc before your cams???? just run lower boost until it matches that hz's.. add some fuel %5 or so up top because of the increased airflow up top.
that will atleast get you by until you get tuned again.
Old Mar 25, 2005 | 04:15 PM
ThEHiTMaN's Avatar
Yes the flash took the fuel cut out. I do not remember what my hz where b4 the flash but I do know what they are now and I do not have cams yet. Max is around 1816hz at WOT.
Dead-Man Inc
May 9, 2006 03:38 AM
EVOlution561
10
Mar 23, 2006 06:47 AM
Evo82nr
15
Mar 16, 2005 08:47 PM
evoguy
Feb 15, 2004 01:12 PM
bpclements
Dec 19, 2003 07:33 AM
