Blacking out headlights
Old Mar 16, 2005 | 10:58 PM
EVOKing8's Avatar
Is taking apart the headlights easier then taking apart the tails??? Any advice for the headlights?
Old Mar 16, 2005 | 11:36 PM
kataklyzm's Avatar
headlights are easy if you have a blowdryer/heatgun, flathead and a razor. i blacked out mine in about 1 hour. the taillights i have not figured out how to take them apart, as it isnt the same glue holding it together, where the headlights use a softer silicone-ish glue, the rear lights have a seal which is hard, and my blowdryer and razor didnt seem to have any effect on it
Old Mar 17, 2005 | 04:30 AM
evolute's Avatar
the headlights are easy and the taillights are HARD.
do some searching and you'll find all kinds of tips on how to blackout both (i hear it's much easier to do the tails if you use a dremel tool instead of heat, which does nothing on that hard sealant)
Old Mar 17, 2005 | 04:41 AM
EVOTEXAS's Avatar
Heatgun for the headlights, dremel tool for the taillights. It's all over the forums. There is even a How To thread with a video! Search.
Old Mar 17, 2005 | 09:59 AM
EVOKing8's Avatar
headlights so easy!! how do u remove the glue??
Old Mar 17, 2005 | 10:53 AM
kataklyzm's Avatar
heat up the glue at a corner and pry it open...it'll strech and just cut it. its almost like gum
Old Mar 17, 2005 | 03:06 PM
EVOKing8's Avatar
iight sweet both are apart and sanded now i need to paint! should i do gloss black or flat black
Old Mar 17, 2005 | 03:11 PM
EVOTEXAS's Avatar
whatever you like.
Old Mar 17, 2005 | 06:01 PM
EVOKing8's Avatar
Guys how do you put them back together if you used a heat gun to take em apart????
Old Mar 17, 2005 | 06:06 PM
Itsmeeeugene's Avatar
u need to get a new sealant to seal it back such as silicon.
Old Mar 17, 2005 | 06:12 PM
navypaul's Avatar
yeah i hear its preaty easy and i do want to try it for future projects but honestly on my car i called in to see how much new headlights would cost in case i ****ed them up cause they surely wouldent have been covered by waranty and i wanted to b sure i could replace them in case i messed up and the prices were outragious they cost like $1000 each for the fronts and $600 each for the backs so i decided that i would rather buy them out of jap JDM rather then take a chance... ive also seen a few peeps here in town who have pride them open and blacked them out honestly i think the original MR JDM look a hell of alot cleaner u can check out mine here
http://i3.photobucket.com/albums/y62...o/CIMG0717.jpg
Old Mar 17, 2005 | 06:42 PM
BuLocal's Avatar
Have you seen this:
https://www.evolutionm.net/forums/sh...ad.php?t=78174
Old Mar 17, 2005 | 06:43 PM
04Evo8RS's Avatar
hey dont screw your headlights up send them to EVODAVE hell do the best job ever and he aint expensive at all..dont take the chance of screwing your headlights up
Old Mar 17, 2005 | 07:39 PM
EVOKing8's Avatar
bro taking them apart is easy as ****....i wanna know the methods people used to put them back together
Old Mar 17, 2005 | 07:43 PM
jrhecker's Avatar
use a gloss paint, i used a flat black, then i put them back together, didn't like them, and had to redo the whole thing, i definetly recommend the gloss, use high temp paint also
to reseal just use a sealant, and press them together then use rubber bands all over the lights to keep them tight till they dry, use a ton of rubber bands and plenty of sealant to avoid leaks or moisture build up
