downshifting with the Evo
Old Mar 18, 2005 | 01:43 PM
osunick's Avatar
Double clutching is a useful skill to have, since synchros or not, it reduces the wear on your tranny. I double clutch when puttering around town and usually just downshift normally on the track. It all evens out in the end. Oh, I change my own transmission fluid regularly and use Redline MT90. Not much harder than changing your oil. I think that helps too.
Old Mar 18, 2005 | 01:45 PM
oak2207's Avatar
I've driven stick since I was 15, learned to drive on a stick. I'm 26 now and have yet to have a single synchro go out. Like I said, I don't beat on it or slam it into gear or anything. My roommate has a 2000 Prelude and he's gotta be the worst downshifter ever, doesn't even rev match, just downshifts and drags the clutch out to slow down. His tranny doesn't have a notch in it.
So to those who do double cluch...how fast can you do it? Seems like it would take a while to get all of those sequences down, and quickly.
Old Mar 18, 2005 | 01:47 PM
osunick's Avatar
A very useful link:
http://www.g-speed.com/pbh/double-clutch.html
Old Mar 18, 2005 | 01:56 PM
oak2207's Avatar
Good info in there! I'll practice double clutching on the way home from work.
Old Mar 18, 2005 | 02:00 PM
osunick's Avatar
Start out slow. The hardest thing is getting the sequence right. You want to rev after downshifting the lever, and you're supposed to rev in neutral, then clutch in and shift. I kept messing up the sequence. The nice thing is that you aren't doing any damage to your tranny, you're just using the synchros like normal. Heel-toe downshifting is also good to learn but harder, but also good for the synchros since braking with the car in neutral slows down the output shaft in relation to the layshaft and therefore makes the job of the synchro easier.
Old Mar 18, 2005 | 02:03 PM
vegeta irie's Avatar
Here's my question. after you have already downshifted and are in gear and about to let the clutch out. Do you dump it or slip it out?
Old Mar 18, 2005 | 02:31 PM
Mercenary3's Avatar
Originally Posted by feldguy
And how many times has your tranny been rebuilt? Im on three now, and I can say I drive better than anybody I know personally. Better safe that sorry. I wore out the 3-4, 4-5 syncros twice by just saying "Hey, it has syncros!!"
Im into that tranny for a ton of green, soon to be more. The second build was done very well so now its quite a bit better. The first build was a stocker with no revised parts and I persisted to treat it like $hit. It rewarded me with twice the problems, so a word to the wise. A quick muscle flex and a twitch of the wrist extra is worth IMHO.
As for the beer, where you at, man? Im in NJ, Im buyin.
You cant just do whatever you want becasue it has synchros. Everything has design intents and limits. I would tend to think that most people who have gone through 2 trannys in this case, or 3 TC's and who knows what else have exceeded these limits in one way or another, if you know what I mean. The BEST drivers know the limits of their equipment, and drive as smooth as they can without forcing anything. Im not saying theres no faulty gearboxes out there...but just like most human-machine interactions, the ratio of operator error to machine error is high.
The synchros should be able to handle casual 1 gear downshifts at moderate RPMs. The time you really need to worry about double clutching are those 5-3 downshifts at 65 mph, etc. This goes for any car though.
Personally, I think if youre just cruising at about 25 in 3rd, and you want to go to 2nd for a turn, double clutching really isnt necessary.
Just be nice to youre car, if you feel like it doenst want to do something, youre prolly right. Back off.
Edit: BTW never shift into first unless youre going under 3 or 4 mph.
Old Mar 18, 2005 | 02:46 PM
Theibault's Avatar
You mean you have to use the clutch when you downshift?
Old Mar 18, 2005 | 02:50 PM
Mercenary3's Avatar
^ haha...no only when you sideshift
Old Mar 18, 2005 | 02:52 PM
SilverStreak's Avatar
Awesome post and info! Apparently, I've been double clutching wrong this whole time and never knew it.
Old Mar 18, 2005 | 03:09 PM
Monkey's Avatar
so downshifting is better for the tranny than putting it in neutral and coasting to a stop? or vice-versa?
Your last sentence confused me a bit.
Old Mar 18, 2005 | 03:12 PM
EVO_ATE_U's Avatar
BTW, using inertia is better than building revs all over again. You're still a loser. :-)
Old Mar 18, 2005 | 03:19 PM
feldguy's Avatar
Merc, I understand that. I didn't, however. I do regard myself as a good driver, but Im much better now than I was when I put a hurtin on the first. The trannies are tight as strong as they come, but not to the extent I had expected. Lesson learned.
Old Mar 18, 2005 | 03:31 PM
feldguy's Avatar
Oh, and your statement about downshifting into first became highly apparent on rebuild #2 (third tranny setup). The tranny has all new syncros, a new input shaft and two dozen associated parts. It grinds 5th, mostly attributed to the TSB and the Cusco 2 disk, which also makes it har shifting on the car, so I've gotta have extra care. Really, I baby the tranny and the only gear I really snap hard is the 1-2 shift. Its not a drag car, so I dont drive it like one. Feeling the syncros engage is necessary, especially with the problems associated with the 2 disk clutch I can't seem to remedy. Any opinions on that?
Old Mar 18, 2005 | 03:49 PM
osunick's Avatar
No, neutral and coasting to a stop is fine. Just be sure to let up on the clutch when you're in neutral.
