Evo 8 Vs S2000
Old Mar 28, 2005 | 06:49 AM
Taimur's Avatar
I have owned both cars. And between the two the S2000 is a funner car. I like the Evo's power and handling no doubt but the S2000s only weakness is lack of power. Besides that the S2000 drove like it was on rails. And I cannot say that about the Evo even though the handling is one of the best. (Comparing between stock suspensions)
But my most favorite to drive is the NSX period! And I have driven many different cars. Nothing like seeing the road 2 feet ahead of your feet and a 8000 rpm vtec engine roaring behind you. (Also the biggest weakness is lack of power)
Old Mar 28, 2005 | 06:54 AM
Tsurara's Avatar
The S2K is a great car, handles very very well and can keep up with more powerful cars because of the suspension setup. They are fun little cars and I like them a lot. My girlfriend wants one so hopefully it can be in the same garage as my EVO
Old Mar 28, 2005 | 07:00 AM
Kwman's Avatar
The evo trust me...when people start making smarty butt comments about it and you start to feel bland and the same in it (if it ever happens) stick on the next mod...and do 0-60 in 3.7 seconds on a G-tech Pro RR
Old Mar 28, 2005 | 07:01 AM
gbpkr21's Avatar
I have never owned an S2000, but I have driven one....I think they are a more fun car to drive. The Evo is faster and a is an overall better performing car, but the S2000 is a really fun car. It is almost like driving a motorcycle...just not as much power. I think the S2000 is a better looking car as well. Good luck on your choice.
Old Mar 28, 2005 | 07:32 AM
mooreboost's Avatar
I have owned both.
My reason for switching was practicality, the S has none. If you get an MBC on the Evo to get rid of the boost taper, then the Evo's powerband is alot more fun. Like someone said on here, "VTEC- all the lag, none of the turbo"... The handling is close, but Im willing to sacrafice alittle grip for AWD, but I have POS tires on my Evo now, and once I get nice ones on there Im sure it will blow the S's handling out of the water.
Two things I miss about my S- The Evo is not built like a Honda, few cars are. You will have to get used to rattles and noises. And two, the Evo doesn't have the class and looks of the S. Both cars get looks, but most people are in awe of the entire car when it comes to the S, while most other people gawk over the huge red brakes, wing and so forth on the Evo.
If I had the chance to do everything over again, I definitely would.
Another thing you have to consider is power. If you're not pleased with how fast the S is stock, and you don't want to spend 5,000 on a supercharger, then give up. Bolt on's don't do a thing on the S, and modifying it is very costly.
Old Mar 28, 2005 | 07:57 AM
WildRice's Avatar
For driving fun nothing beats topless. The Evo is a four door compact sedan, different in evey way and for different purposes. I like to play in my garage and machine shop so the Evo is a great platform for me. As an old Elan S2 fan ("the car that Clark drives" my he R.I.P.), I will have a Lotus before I am put out to pasture.
Old Mar 28, 2005 | 08:07 AM
WHTEVO's Avatar
i have driven both, also driven a sc s2000 as well as a n/a one and i would have to say go with the evo. don't know how tall you are, but i am 6'2 and after a couple of hours in the s2000 my legs would start to cramp up from not enough room to move. s2000 is a fun car but as far as picking from the two from a whole, go for the evo.
Old Mar 28, 2005 | 08:17 AM
Soon2BEVO's Avatar
Originally Posted by threepointsix
EVO can run 12.80@110 for $2500 or less depending who does the modds.
MUCH LESS! The car with a reflash and $80 boost controller can run 12.6-9. I have no track times yet but I pulled my friends 2G Talon that went 12.3@112 on pump. I was on pump as well. I know my car will trap better, I just hope to get that low ET!
Anyway, Ive driven an S2000, they are fun, but like someone else said, ya really have to drive it like you stole it to get that 10 fun factor out of it. The EVO is fun to drive anywhere over 2800rpm! Plus, I just prefer AWD!
Old Mar 28, 2005 | 08:18 AM
TurboWill's Avatar
I had a deposit on an S2000. I loved the car. Before I bought it though, I knew the Evo just arrived. So I went down to Mitsubishi and test drove the Evo. So here I am as an Evo owner. By the way our Vtec is the Turbo. It kicks in around 4000rpm Stays that way to redline.
Old Mar 28, 2005 | 08:46 AM
Thoe99's Avatar
Originally Posted by plokivos
obviously you've never driven s2k hard.
evo is overall better car, but fun factor stock vs stock or slightly modded, s2k is far better than evo.
When that vtec kicks in at 9000 rpm (1st gen), you could feel all the power just pouring in all at once and it's different from turbo kick. it's more violent.
You can't go wrong with either one, but if you want something with AWD and space, i would go with an evo.
convertible driving, can't beat that though. The spring is here, finally.
I've driven both cars, and in fact, was one foot away from buying the S2000 at the time. Had they let me test drive it, I might have had the S2000 today. The poster would probably benefit more from the S2000, cuz he seems like that kinda guy. S2000 is not a far better car than the Evo. It is a better driver's car, thats for sure. It just makes you more "one with the car," most likely due to how small it is...and the pimp factor is leaps away. The evo still has its pimp factor, but it's a different kind.
Vtec kicks in at 6000rpm, not 9000. No, it is no turbo. It is very far from a turbo. It barely put a dent in my seat when it kicked in during my drives. Hate to say it, the acceleration 'felt' like a civic's. The sound note change is the only thing that makes it 'seem' like it's going faster, but Vtec is like a hiccup, sorry.
Overall, they are really two totally different cars. On an autox course, the Evo is in a higher stock class than the S2000. Even though the S2000, IMO, is just as capable as the Evo on that track, not very many people could tame that car well.
Old Mar 28, 2005 | 09:01 AM
lil'evil_evo's Avatar
Drive both and you will have your answer. I can't tell you how happy I feel every time I drive my evo compared to anything else I have driven. This is coming for someone who has had there evo for 2 YEARS.
Old Mar 28, 2005 | 09:08 AM
osu s2k's Avatar
apples to oranges, if it will be your only car evo, hands down. if you have more than one car and want a weekend car that is fun, s2000. why dont you get the s2000 and evo/sti, this seems to be a very common combination.
Old Mar 28, 2005 | 09:12 AM
SterlingEvo's Avatar
You'd be happy with either in different ways... this is a win/win decision...
Old Mar 28, 2005 | 09:16 AM
Ev0 loo shun's Avatar
well first off where do u live? if you live in florida, miami, st pete beach, (any beach) cali and your not lookin to drag race, i would def go with the s2000. its one sexy beast, but what sucks is 2 seater compared to 4 door. honda s2000 hasssss 150 lb/tq? very gay. ruined the car i say. if your lookin to do donuts, show off, hear the turbo wind up (mmmmm) bov, and just a kick *** car.....go with the EVO
Old Mar 28, 2005 | 09:28 AM
mrmefodman's Avatar
Originally Posted by emopunk96
You make very valid points...I realize that the EVO is much easier to power(much like any dsm)..but I guess I was just worried about the evo being "to good" were the fun out of driving would be takin out by all the new electronics I hear about on these cars...then again thats prolly mostly the MR with its active yaw and what not correct?
btw, how do you like the RS? I dont plan on getting one as a daily driver, so the RS seemed almost a perfect option and a steal for 27.5k.
I bought myne last June. To tell you how much i still love the "DRIVE" i Have yet to put in the stereo after 10 mo. (smiles to himself thinking of where that money went) Also another side note, it is my daily driver as i have put 20,000miles on it with out the stereo.And I love music. Thing is with the rs, it is so raw that it just pulls u into the experience and everything else in you life is non existant as you pull through the coner tail wide.
