A Must Read Help!!!!!
Old Mar 30, 2005 | 06:30 PM
Kuba23's Avatar
I went to the track today but...
I launched at around 6000 rpm i got the exedy twin plate with 3k miles on it
**** started slipping in every gear i trapped a crappy 110 and my quarter mile was 13.4 slippin every gear then i get my time slip park my car and THENNNN I come back start my car and cant put it into ANY GEAR i mean any GEAR the car was cool and still couldnt put it into any gear... after two hours of ****in around everyone was lookin at my car I put it into second start the car and start drivin home all the sudden all the gears work but the shiffting fells very strange and hard at points ANY IDEA what that might be ???? please HELP
Old Mar 30, 2005 | 06:32 PM
tke_413's Avatar
Go back to wherever you had the clutch installed at, buy another clutch, and see if they'll cut you a deal for a second install.
Erik@MIL.SPEC's Avatar
Don't know, but it doesn't sound good.
Old Mar 30, 2005 | 06:37 PM
Ev0 loo shun's Avatar
That was alot of help
Old Mar 30, 2005 | 06:38 PM
Kuba23's Avatar
I never ever launched my car i did it for the first time today and this **** happens UNREAL...
Old Mar 30, 2005 | 06:40 PM
Kuba23's Avatar
1500$ clutch plus labor for 3k Miles and only one launch ???? my stock clutch held up for 13K miles and it was not even half way used up....
Old Mar 30, 2005 | 06:41 PM
That's why I said 'I don't know.'
Old Mar 30, 2005 | 06:59 PM
Natalie Ridgway's Avatar
Do you have brass aftermarket shift bushings at the tranny? If you do they might be seizing up on you if you didn't lube them well. I can't tell you anything about the clutch though. Good luck
Old Mar 30, 2005 | 07:02 PM
AutobonEvo's Avatar
clutch's normally have warranty's on it. My SACH for my gti had a 2 year warrenty and it started slippin after 2 years they replaced it and put it in for free. Maybe try resurface your flywheel. O also it could have some film on it from launching it so hard, drive it around for another 1 or 2 days (slowly) problem doesnt go away try gettin it done under warranty (the clutchs warranty). Good luck and keep me updated on how it goes.
Old Mar 30, 2005 | 07:05 PM
DCSilvrEvo's Avatar
I think 6000 is way too high man. when you shifted did you have your clutch all the way in? I never launch @ 6000 Always 4500-5000.
Old Mar 30, 2005 | 07:47 PM
freds4's Avatar
Did you remove the stock pill from the clutch line? If not, then any clutch will slip upon launching the car because the pill limits how fast the clutch can be released. The first time my stock clutch slipped at the track I did some research, learned about the pill, removed it and have had no trouble since. My car is two years old, raced often and still on the stock clutch.
Old Mar 30, 2005 | 09:07 PM
Kuba23's Avatar
HMM thank you soo much guys for all the Helpful hits imma try everything tomorrow once i wake up.. I drove the car around and in every gear the clutch feels like it did before STRONG and does not want to slip... MY main concern is that the GEARS feel very very weird sometimes it feels like something is broken when i try shifting into a gear feels like its not in its RIGH TPLACE
BTW i do have those bushings i did lube them up i originally thought that might of been it imma take everything out tomorrow morning back track every step i took and see what it might be and i will be takin the car to Turbotrixx tomorrow hopefully they can help..
Old Mar 30, 2005 | 09:17 PM
invazn's Avatar
trappin 110 u should be in mid/high 12's??
Old Mar 31, 2005 | 01:34 AM
DynoFlash's Avatar
Kuba - just speculation - but sometimes the center release bearing can pop out if the transmission is not properly re-installed after a clutch job and there i sany dirt or grease on the mouting surfaces causing misalignment. The bearing may have snapped back in. I would get it checked out.
Old Mar 31, 2005 | 05:35 AM
Kuba23's Avatar
Thanx Al i am going back to turbotrix to see what went wrong we sorta thought it was either the clutch or the bearing it definetelly feels weird.. My only question is how come the clutch was slipping in every gear ?? and then when i was drivin home it felt normal..
