Adjusting Greddy TypeS Bov
Old Apr 11, 2005 | 08:51 PM
qbbraveheart's Avatar
ok I did the single spring mod on my typeS and i have it recirc. back into the intake of course
I set the adjustment at 2 1/2 turns from 1st contact
it would be fine but for like less than a second it would start to whistle at 0.4kg or whatever it is on the boost gauge and then go away
so I adjusted it to 3 turns and it does it even more now
what is this whistling and why is it doin it in vacuum?
is this compressor surge?
should I go back to 2 1/2 turns or what?
need some help with this cuz im confused lol
TIA
Old Apr 11, 2005 | 08:53 PM
DCSilvrEvo's Avatar
no mind does the same
the valve is opening slightly and letting air out. i dont know if its normal but my car does it and its annoying as hell!!!!!!!!!!
Old Apr 11, 2005 | 08:56 PM
yea mine does it even more now that I adjusted it to 3 turns
I just dont get the whole thing of adjusting it
like when do you know you have to adjust it?
should I put it back to 2 1/2 turns?
Old Apr 11, 2005 | 11:48 PM
precisi0n's Avatar
same hear... mine whistles as well
Old Apr 11, 2005 | 11:58 PM
inline4g63's Avatar
you get used to it.
Old Apr 12, 2005 | 08:44 AM
oh ok
but I would still like to know when youre supposed to make it harder or softer
thats really the thing I dont get
Old Apr 12, 2005 | 08:59 AM
sleet's Avatar
I think somone posted here that the "screw" shouldn't be touched and they regret that they ever put that on the valve.
Old Apr 12, 2005 | 09:18 AM
mdosu's Avatar
Originally Posted by qbbraveheart
oh ok
ok I read your signature on your mods...and it looks like, your car is basically stock...if you are running stock boost...just make sure your valve is
1. peaking at the right boost
2. holding it at the right boost, maybe a bit higher..but def. at bit longer than stock.
3. should be blowing off freely if #1 and #2 holds true.
If you're not peaking at the right boost, it's too soft and its letting out too freely ~ "leaking"
if 1 and 2 is true, but 3 is not, it is on too tight and you can tell if it's fluttering.
hope this helps.
Old Apr 12, 2005 | 09:21 AM
mdosu's Avatar
my buddy John modded my type-s screw bolt/shaft out. we took the original one out and put in a 10 metric in that had a single hex head. I marked 2 of the sides of the hex with permanent marker so I have a good idea how many turns I am making and degrees of adjustments I am making.
