Exhaust messing up Paint...
Old Apr 16, 2005 | 10:31 PM
vtlaxplaya16's Avatar
I just picked up my Evo today, It has RnR exhaust on it, with the bumper shield, but I noticed that the whole rear right of the car is faded because of the exhaust fumes, is there anything i can buy to wash it off maybe?IVe tried soap and water but no luck. The car is weightless white so it shows pretty good. thanks for any help!
Old Apr 16, 2005 | 10:33 PM
housedj's Avatar
Thumbs up
a good wash, a clay bar, & some Meguiar's NXT wax buffed by hand should do the trick.
Old Apr 16, 2005 | 10:36 PM
Secret Chimp's Avatar
Clay bar the paint is a good start. But make sure you wash the bumper with a dishwashing soap first to remove any built up wax first.
Since clay is only meant to remove surface contaminants, it may not clear up the problem. If the paint is discolored, you may need to use some polish or cleaner prep wax. Cleaner prep wax tends to have cleaners but no abrasives. So if you are afraid to use a polish on your car, try the cleaner first. If that doesn't work, you will be forced to use polish. If you have no experience with polishes, you might want to bring your car over to the local detailing shop.
Once the paint is smooth and free of stains, go find some high temp wax. The wheel wax available at www.poorboysworld.com works great. Since it doesn't vaporize as easily as normal waxes in high temp situations, it will hold up better to the heat coming from the exhaust vapors and keep the bumper from staining better than a conventional wax.
SC~ who is a car detailer
Old Apr 16, 2005 | 11:39 PM
Soon2BEVO's Avatar
I noticed my rear bumper was looking funky, I washed it and the haze of film was still there. So I took some cleaner wax, applied it, and that took it off, then I waxed the rear bumper twice. Its been better since. However, I dont actually think its just the exhaust fumes. I think its when the exhaust fumes mix with water on the bumper that is creates this problem.
I thought I remember reading somewhere C02 and H20 together cause some sort of reaction, I could be WAY OFF so dont hesitiate to correct me. It seemed that the film ONLY comes back after I let my car sit on when its wet out(dew or rain).
I got the film off roughly 2 weeks ago and there has been no water on the car since and the film is NOT back on my car, thats why I came to this conclusion.
Old Apr 16, 2005 | 11:58 PM
RED DEMON's Avatar
i use a cleaner called "green stuff" at the dealership i work at, just put some on a towel and it wipes right off
Old Apr 16, 2005 | 11:59 PM
RED DEMON's Avatar
and BTW i have a RSR 3" downpipe with built in cat delete pipe and RSR ExmagII exhaust so my bumper gets SOILED!
Old Apr 17, 2005 | 08:23 AM
Yodobashi's Avatar
I used to have this problem with my Mr2. The best and easiest solution I found was some Meguiar's Crystal cleaner. It comes in Clear-coat and non clear coat form. Here is a link:
http://www.meguiars.com/store_meguia...A-30&store=meg
It's about $5 a bottle. You just wipe it on and it takes the stain right off.
