perplexing air/fuel tuning issue
Old May 7, 2005 | 07:29 AM
d15b7's Avatar
hi guys.
i've got a funny circumstance here that i am dealing with; ecu is all stock, and i have a 2.5" downpipe, cat delete, and rear muff delete. i have tuned the car with a wideband LM-1 (road tune) and a HKS Super AFR.
here's the thing: when i do a WOT pull in 3rd gear on the highway, the A/F is between 11.7 and 12.0 (too lean for my tastes). when i shift into 4th and mash it, the A/F is 11.2 - 11.5 (about where i want it to be).
what is going on here? shouldn't the A/F ratio be gear independant? why is it different depending on what gear it is in?
thanx alot
todd
Old May 7, 2005 | 07:32 AM
housedj's Avatar
what kind of gas are you using? your A/F looks fine to me for your 3rd gear which is your stongest gear. all dyno pulls are done on 3rd gear also.
Old May 7, 2005 | 07:52 AM
d15b7's Avatar
hello!
i am using Texaco 93 octane (here on the East Coast, 93 is all over the place).
i guess i should mention the settings on the Super AFR: they start at 3500 rpm (-1) and work up to 7000 rpm (-12).
i use the car for an everyday driver (20k miles per year) plus the occasional track event (i am an instructor for the PCA and BMW and Ferrari, etc). i want the car to be "safe"; therefore, i am a little concerned with the 3rd gear A/F.
i'm guess i'm still wondering why the A/F would vary to a richer number in 4th gear? i just did another couple of road runs, and it definitely goes down into the 11.1 - 11.2 range when doing a hard pull in 4th. its 11.7-12.0 in 3rd gear.... ?
again, the ecu is oem stock, no mbc, no flash, no electronic boost control....
thanx
todd
Old May 7, 2005 | 07:59 AM
housedj's Avatar
Question
i would highly suggest a flash. if its running rich in 4th, your ECU could be detecting knock, therefore pulling timing. is 93 the highest pump gas you can get. i though they had 94 out there? i know they do in FL.
Old May 7, 2005 | 08:49 AM
d15b7's Avatar
hello again.
i don't think it is knocking; it is pulling like a freight train in 4th, and isn't pulling boost (1.3 bar on the factory gauge) in 4th.
sometimes one can find 94 at a Sunoco, but mostly i use the 93 oct.
keep the theories coming, please!
todd
Old May 7, 2005 | 09:16 AM
housedj's Avatar
how much boost do you run?? maybe you need a little more to "lean it out" ...
Old May 7, 2005 | 09:36 AM
d15b7's Avatar
its stock boost; no flash, no mbc, no ebc.
when i am driving it, especially on track, i want the ecu free to pull timing and boost if it detects any knock... i like the safety features built in to the oem computer; i think oem computer has pretty good "save your butt" features if knock occurs.
therefore, i don't run the commonly used mbc....
todd
Old May 7, 2005 | 09:50 AM
housedj's Avatar
Al's dynoflash retains all the stock ECU safety. he just gets rid of the other limitations like speed limiter, pushes rev limiter to 7800rpm from 7404, & adds timing. with a good flash on 93 octane, you can run about as much timing as i'm running on the '03. at least 9 degrees advance on the 1st 2 gears, & at least 16 degrees advance on 3rd & 4th this is how evos are tuned in FL on 93 octane @20 psi. my '03 on stock cams pulls all the way to 7800 in 3rd & 4th. with aggressive cams, i can add in another 3-4 degrees on all gears. Al even has a dynoflash now where you don't even need a boost controller i think. may have to search tho.
