poor guy
Old May 12, 2005 | 03:28 PM
EVOMIZ's Avatar
I have seen worst.
My friend was racing a r33 skyline last week after installing new pistons and rods 2 weeks before and the whole bottom of the plug broke off in the cylinder
Old May 12, 2005 | 03:30 PM
sabastian458's Avatar
Old May 12, 2005 | 05:32 PM
mooreboost's Avatar
E-manage doesn't have a very good track record...
Old May 12, 2005 | 06:55 PM
qbbraveheart's Avatar
you can say that again
Old May 12, 2005 | 06:57 PM
plokivos's Avatar
is that plug gapped right?
also, did you clean that plug for the picture?
Old May 12, 2005 | 07:07 PM
plokivos's Avatar
Originally Posted by sabastian458
the valves in evo are nitrate filled, meaning if he droped one, it will most likely explode, says the mitsu tech. inspection of the head so far, we only have the rocker cover off, shows that all valves are still seating, but it doesnt mean the end of one hasnt been broken off. hopefull the customer will call us tomorrow and authurize us to remove the head so i can update some more
natrium, not nitrate filled. idiot tech...
natrium is sodium like salt.
"natrium-filled exhaust valves reduce valvetrain inertia and help engine response. The natrium exhaust valves also help lower the temperature of the bell end of the exhaust valve by retaining less heat."
brought to you by number 4028
Old May 12, 2005 | 08:49 PM
Jakeg97's Avatar
sorry to hear. the guys gets cams installed wrong and now hes stuck...
Old May 12, 2005 | 08:57 PM
hawaiievo's Avatar
see you learn something new everyday
Old May 12, 2005 | 10:21 PM
Stormtrooper's Avatar
Thumbs up
damn still sucks for the guy though.....at least the evo will live to drive another day....
Old May 12, 2005 | 10:24 PM
antonio010's Avatar
Yeah I feel bad as well, hopefully his warranty will cover it.
Old May 13, 2005 | 04:56 AM
andrew20195's Avatar
I've never heard of "natrium", but I believe they are sodium filled valves. There is a huge difference between salt and elemental sodium however. Sodium is a highly reactive metal, and when it is exposed to water it basically burns. If you were to cut open a sodium filled valve in a high humidity environment, it is quite possible that a reaction would occur, so although the tech may have been confused, he's not far off the mark.
EDIT: Ok, thinking about it more, I'm guessing natrium is just another name for sodium, hence sodium = Na on the periodic table.
Old May 13, 2005 | 05:21 AM
Old May 13, 2005 | 05:23 AM
Old May 13, 2005 | 05:26 AM
HobieKopek's Avatar
Something similar happened to my plugs. I didn't check compression before tearing apart my block because I knew what happened. Did it sound like someone threw a bunch of change in an empty clothes dryer? What an awful sound.
I'm amazed he ran on 3 cylinders, and I'd also be amazed if he didn't destroy his valves and turbine with fragments of piston.
Old May 13, 2005 | 05:30 AM
