300hp Tuning Cost?
Old Feb 14, 2003 | 04:48 PM
  #46
I-SpeedUSA's Avatar
Just wondering if you are talking wheel horsepower or cranks horsepower. As there is some loss in power to the wheels especially on all wheel drive vehicles.
Old Feb 14, 2003 | 06:31 PM
  #48
boostedwrx's Avatar
cladius is accurate
Old Feb 14, 2003 | 06:50 PM
  #49
I-SpeedUSA's Avatar
This debate over drivetrain loss has been around for quite some time and I have never really figured out the formula for drivetrain horsepower loss. Just trying to state that you may not get the horsepower you expect on a dyno, with more major modifications. As this is what I have noticed with WRX's and RS-T's.
Here is an example of what I am talking about. The WRX flywheel horsepower if 227, yet on a dyno it measures about 165 at the wheels. Not modify it and at the wheels it makes 250, but the crank is usually around 320. So it isn't really a percentage and nto really a value, but seems to be a little of both.
Though I could be totally wrong for the Lancer EVO VIII as I have no real background in mitsubishi cars except for a Mitsubishi Precis from 1988, he he.
Besides that the flow characteristics of the heads, and headers I am going to bet are not as good as the JDM version because of smog specifications. So getting more horsepower out fo them compared to a JDM wil be a little bit tougher.
This is just stuff I have picked up in the Subaru world and woudl assume a lot applies to the Lancer also.
My $0.02
Old Feb 14, 2003 | 08:17 PM
  #50
Turboniam's Avatar
Originally posted by concordmitsunet
well turbanium, simply enough, most fast dsms are run off electronic boost controllers, specifically the greddy profec b when it comes to turbos in the 14b-18g size,
Show me your evidence of "most" fast dsms run an electronic controller??? Where do you come up with this crap???
many 10-11 second times with this controller and any good website that really knows what they are doing will advocate it, just call www.roadraceengineering.com ... forcedperformance.com ... etc and they'll all tell you the same,
ROTFLOL Thats funny, I have spent plenty of money with both shops and I personally KNOW everyone that works at FP and was at the track when they did their testing on several of their turbos!!! BTW, FP & RRE sell MBCs and the one on my car is sold by FP themselves ... Once again you are
save your obnoxious insults, in fact get over whatever your problem is and take it out on someone else.....
Most of the posts I have read from you are ignorant. I tell it like it is, that is all and if you post gay trash, I will call you out on it... simple as that!
the greddy profec b has three things that a manual boost controller does not that from what i have learned, makes it better for the evo,
Again, where do you come up with this?? Do you have an EVO and are you testing various products on it?? I have had electronic and manual boost controllers and without a doubt the best performing controller I have ever used has been a manual.
so with a turbo this size, you cant just expect a manual boost controller to hold as steady boost, i may be wrong, every application is different,
Ya, you may be wrong, because you don't know... but what I do know is that manual controllers are more reliable/better performing than electronic controllers from real life testing.
but if thats not enough for you, then go ahead and tell me why not rather than just talking smack
I just did!!!
Old Feb 14, 2003 | 08:21 PM
  #51
Turboniam's Avatar
Originally posted by Claudius
Turboniam, I think electronic boost controllers enable you to control the boost much better over the whole rev range, through the gears, start duty, etc. Why do you say a manual is better?
From my personal set-up, at this time the manual is by far the best performing... however, on the various other set-ups I have had, I have used both electronic and manual and the maual controller was so much more reliable and performed so much better than any of the electonic controllers I had... the convinience part of the electronic is great, but the function of the manual is why I choose it.
Old Feb 14, 2003 | 08:26 PM
  #52
Turboniam's Avatar
Originally posted by boostedwrx
Manual boost controllers do suck. They suck BIG TIME. Have you ever noticed why you need to set your MBC in 3rd or maybe even 4th depending on vehicle????? Because if you set desired boost in a lower gear you will be running super high in 4th or 5th.
That is because of your car... I have a friend who has a WRX and had the same problem... off course it is nicely modded now and I don't think he is having the same problem... but he is using a AVCR now from the bleeder style mbc (YUCK) he had on it so there is really no apples to apples comparison. But the reason he isn't having the problem is not due to the AVCR.
I also had the same problem at one time, but that was due to my waste gate, not the BC.
Old Feb 14, 2003 | 08:31 PM
  #53
Turboniam's Avatar
Originally posted by chronohunter
Do you have any dyno pulls (with and without) from guys using propane. I've heard of people using it but have never seen results
During what I would call the "early days" of testing this on gas powered cars, there was a shop that was initially making a kit and they were testing it on a Supra and if I am not mistaken, the guy was able to run an 11.0 vs the 11.6 without the propane.
I haven't really kept up with it latley, but I know there are a few people out there with kits on various different cars... all that I have read seems to be favorable.
Old Feb 14, 2003 | 08:36 PM
  #54
Turboniam's Avatar
No; the restrictor is in a hose that goes to the wastegate actuator. The smaller the inner diameter of that little restrictor, the more boost it will take to open the wastegate. That's why I said you could just hammer on it. In fact, Maxi did that and he's got 320 bhp in his Evo 5 now (276 bhp stock). Running just under fuel cut level at 1.2 bars.
That sounds very similar to the same type of "free mod" that was done on the DSMs... except you would pull out a "sleeve" in the stock BCS and it would give you an extra pound or so of boost.
The thing is, you wont get any boost control with that, just a little more boost. If you hammer it too hard, you can get bad overboost and det / engine damage. I'd spend the $40-50 and get a Dawes or equivalent In fact, I'd spend more than that and get an AVC-R to control boost effectively.
Later
Claudius
For less than $50 you can't go wrong with a quality MBC such as the one your mention or one from www.joepmbc.com
Old Feb 14, 2003 | 09:53 PM
  #55
chronohunter's Avatar
Cant use a manual controler where I live I can drive anywhere from 5200ft to over 10,000+ in a single spirited drive and the manual can't compinsate for the changes in altitude like an electronic (I use the Blitz dual selonoid unit). The amount or air bled needs to change (more air at higher alt.) to keep a constant pressure or you lose even more hp at altitude.
I like the simplicity of a manual unit (and price and response) but they don't work well here (Co.)
Old Feb 15, 2003 | 04:46 AM
  #57
Turboniam's Avatar
In a situation such as yours with the drastic change in altitude, I can see why you would use the electronic over the manual.
Old Feb 15, 2003 | 04:54 AM
  #58
Turboniam's Avatar
I cant see how a manual boost controller has better "functon" over an electronic one.
As previously stated, you need to set the manual BC up in 4th or 5th gear to make sure it doesnt overboost in the higher gears. This will mean less boost in lower gears. With an electronic BC, you can get the same boost in all gears if you want. I suppose the electronic BC you tried was faulty or not set up completely if it was less good.
My manual BC has the same boost in gears 3-5... it is literally rock solid!
I can't say the same through the use of the electronics controllers.
Also, another type of BC I can't stand are the bleeder type manauls... I have a TurboXS dual stage MBC that totally blows that I bought off a friend mine... I've been meaning to sell it... it spikes horribly. FYI
Old Feb 15, 2003 | 10:45 PM
  #59
concordmitsunet's Avatar
i bought my turbo from forcedperformance, and their fastest times on the similar turbo to the evos are using the greddy profec b electronic boost controller, ask robert, he owns the place,
Edited so this thread doesn't turn into a flame fest AGAIN
Old Feb 15, 2003 | 11:39 PM
  #60
Nzo's Avatar
Nzo
It will be interesting when someone actually gets a US-Spec Evo8. At this point it's all just a bunch of guys masturbating to pictures and numbers. I feel sorry for all you guys with such astonomical expectations. Here is a collection of quotes which made me laugh.
I'd say cold air intake and cat back exhaust and you'd be sitting really close to 300hp. If not, really, really close.
So CAI and exhaust give 30hp these days? I gotta get me some of that!
I have to agree with 4g63 Attack, a boost controller will probably be the cheapest (less than $50) and easiest way to get the car from 271 to 300 fwhp
don't worry, a stock evo will outhandle a stock STi anyday, anywhere
For less than $1000, I'm sure you can get EVO to 330-340 hp. The BC is a must, but to push the extra PSI even with low octane gas like the 91 out here in CA, you can get a propane injection system...
Ah, keep up the good work and keep the comedy comming guys!
