300hp Tuning Cost?
Old Feb 16, 2003 | 12:03 AM
  #61
gtr's Avatar
gtr
http://www.rcdevelopments.com/index2.htm
Check out the evo 7 stage tunning. Seem very basic mods to get the power up. Our evo 8 will probably be similar and i'm guess the computer is what's holding us back. We just need JDM mapping with less aggressive timing from fuel.
Old Feb 16, 2003 | 12:14 AM
  #62
JeffGST's Avatar
Every boost controller, whether it be a manual or an electronic, must be tuned in some way.
ALSO, every boost controller must be tuned in at least 3rd gear or higher. This does not mean that the controllers are defective. The boost the engine receives in 1st and 2nd gear will ALWAYS be different than 3rd and beyond if you have more than 250 hp. Even if you bought the most expensive boost controller in the world, you could not get consistant boost in every gear at high psi levels.
THIS IS THE REASON!!
If you have a large turbo set at 22 psi, you will notice that the highest boost level you will get in 1st gear is around 14-15 psi. 2nd gear you might get it up to 19 psi, and finally 3rd - 5th gear you will boost the desired 22 psi. The reason is because the RPM fly up so quickly in 1st and 2nd, that the turbo has no time to get to full boost. Once again in 2nd, redline gets there so quickly that it only had time to get to around 19 psi. 3rd gear is a nice long gear so that you have enough time to get that turbo spinning to 22 psi.
You could even plug the wastegate completely and still not get full boost in 1st and 2nd no matter how hard you try. There are benifits to both manual and electronic, but the downside of the expensive electronic boost controller are not the inconsistant boost levels between gears. 3rd - 5th are always rock solid boost control with the electronic unit. If you are complaining about spikes in boost, you better blame your restrictive wastegate that you are using.
jeff
Old Feb 16, 2003 | 09:04 AM
  #64
limey's Avatar
where does all this stuff go without making your evo dash look like the flight deck of the shuttle.....Turbo Timers,Boost controlers, exhaust gas temprature guages, boost gauges, AF ratio gauges, fuel pressure guages, G-Tech pro, Radar detector....have I missed anything?.....could someone tell me just the essentials...after all I would prefer it if my evo remained a 5 seater........
Old Feb 16, 2003 | 02:09 PM
  #66
limey's Avatar
Thanks claudius.....oh and the krupps cuppacino machine needs to be installed so we can enjoy a frothy coffee at.97g
Old Feb 17, 2003 | 05:39 PM
  #67
Turboniam's Avatar
Jeff and Claudius, I think we agree for the most part... Jeff brought up a good point on the waste gate issue... through out my various set-ups the manual was by far the most reliable and best functioning compared to the electronics I tried/used... however, with my latest set-up it would be interesting to see how an electronic would compare to my current manual BC... the waste gate is not an issue these days
Old Feb 18, 2003 | 06:37 AM
  #69
limey's Avatar
Old Feb 21, 2003 | 11:57 PM
  #70
brassmonkeyboy's Avatar
WRONG...up to 330 w/warranty
Originally posted by GSXTREME95
<Maybe a dumb question...but what upgrades can be done to boost HP WITHOUT voiding the warranty?>
None
you're totally wrong. If you get the parts from Ralliart, Mitsu's rally-division, then your warranty covers up to 330 HP.
i work for a dealership that sells mitsus, and that's what they've told us
Old Feb 22, 2003 | 01:04 AM
  #71
Turboniam's Avatar
I hope you are right!
Old Feb 23, 2003 | 08:13 PM
  #72
don't worry
I'm definately right :-)
Old Jan 27, 2004 | 09:00 AM
  #73
bhaath burner's Avatar
but dont ralliart parts cost a lot of money??
Old Jan 27, 2004 | 09:58 AM
  #74
mifesto's Avatar
i got exhaust, highflow cat, and CAI and im pushing 310bhp easy.... and once i get a ecu reflash... i'll be hitting 330bhp easily.... all for cost of $1300
Old Jan 27, 2004 | 02:55 PM
  #75
whoa... now where can i get goodies like that
