Can a hallman Manual Boost Controller be bad for your car?????
Old May 13, 2005 | 05:46 PM
bmaga123's Avatar
Question Can a hallman Manual Boost Controller be bad for your car?????
I was thinking of getting a Hallman boost controller installed and my car so I can run 21psi all the way up to redline. Could this hurt my car in anyway or is it safe?
Old May 13, 2005 | 05:52 PM
bmaga123's Avatar
Would this be an ok first mod on my 05 RS? Would it void warranty?
Old May 13, 2005 | 06:22 PM
skiracer's Avatar
Yes it will void your warranty. Unless u take it off before going to the dealer.
Old May 13, 2005 | 06:27 PM
mike69's Avatar
Best first mod is a boost guage.
Old May 13, 2005 | 07:24 PM
03BREvo8's Avatar
get both at the same time.. cost you bout 100$
Old May 13, 2005 | 07:25 PM
Warrtalon's Avatar
He already has one.
Old May 13, 2005 | 07:31 PM
j8's Avatar
j8
I never ran my boost over 19psi until I got a tune on the car. Just my two cents.
Old May 13, 2005 | 08:25 PM
jimmyv65's Avatar
Mee too, but the tune doesn't really add a margin of safety. The tune lean things out. Pre tune richer conditions are technically safer.
IMHO--I'd get an exhaust or a flash before the MBC.
I think dynoflash now has a feature that holds the boost at 20psi without the MBC. Doing that kills two birds with one stone.
Old May 13, 2005 | 09:12 PM
import111's Avatar
I give thumbs down for MBC. I give thumbs up for reflash/EMS + TBE.
Old May 13, 2005 | 11:30 PM
plokivos's Avatar
you're at below 10afr by 4000 rpm on stock evo.
if you boost more, maybe it'll level out a bit better.
no, it wont hurt your car. it may take your turbo out sooner, but not by much compare to you running stock boost level.
tapering sucks.
Old May 13, 2005 | 11:47 PM
Jakeg97's Avatar
yes it will void and no its not a good first mod
get an aftermarket boost gauge as your first mod. the stock ones are junk
Old May 13, 2005 | 11:49 PM
Jakeg97's Avatar
He already has one.
your not talking about the stock one are you?
Old May 13, 2005 | 11:50 PM
Warrtalon's Avatar
Yes, is that a problem? If so, enlighten me as to what makes the stock one "junk."
Old May 14, 2005 | 12:09 AM
Jakeg97's Avatar
just from what i read , search works great
https://www.evolutionm.net/forums/sh...ck+boost+gauge
its like comparing the stock intake to an aftermarket one.
the aftermarket intake makes the stock one look and perform like 'junk'
Old May 14, 2005 | 01:37 AM
bmaga123's Avatar
My stock boost gauge seems to work great.
