Help! Need Bov.. What Type?
Old May 19, 2005 | 10:27 PM
one_fas_evo's Avatar
Question Help! Need Bov.. What Type?
as stated on the headliner. i'm new to this evo life. i just got mines 2 months ago. i know little about this vehilcle. i have vishnu stage 1++. i need help deciding what type of BOV to get. here's what i have in mind so far.
HKS SSQV BOV ver. 2
FORGE
GREDDY TYPE R
GREDDY TYPE S
please note that i need something that will hold up to 27 psi and not leak, stall, or fogg. i would also prefer to have one that actually produce the blow off noise. PLEASE HELP! thanks in davnce you guys.
Old May 19, 2005 | 10:35 PM
xLaNcErEvOx's Avatar
tial?
Old May 19, 2005 | 10:36 PM
trinydex's Avatar
get a crushed 1g... that meets all the requirements and won't mess up or need to be fiddled with. just works.
Old May 19, 2005 | 10:41 PM
crush 1g? you mean physically crush it? please breask it down. thanks
Old May 19, 2005 | 10:44 PM
Originally Posted by xLaNcErEvOx
tial?
do you ahve this? or do you know anyone that own this BOV?
Old May 19, 2005 | 11:31 PM
Warrtalon's Avatar
A crushed 1g BOV will not come close to holding 27psi. Maybe 21-22, but definitely not 27. You can only crush it until the nipple touches the housing...
Old May 19, 2005 | 11:48 PM
gnulooks's Avatar
I run the forge BOV, which works great and holds lotsa boost. Smogrunner ran the Greddy Type S, but ditched it for the stock stealth look of the forge. Its probably one of the better BOV's you can get and it won't cost you and arm and a leg.
Call Vivid they usually have them in stock.
Old May 19, 2005 | 11:53 PM
trinydex's Avatar
the 1g bov is the same as the mr bov, EXACTLY... but it's cheaper... you can get one with an additional leak stop mod from dejon tools.
i know of people holding more than 30psi with no drivability, leaking, bucking, surging problems. you can call bs on this all you want. but these people are tuning and tracking evos and don't fuddle with the bull****. btw.... robi is one of these people.
this is a quote from scoobysteve at socalevo
Originally Posted by ScoobySteve
The JDM MR bypass valve is the exact same BPV the stock WRX's and STi's come with, they are the metal 1g's. For the most part the 1g has been successfully holding around 21-22psi without any leak, on rare occassions, some flutter or leak, but more times than not that isn't the case. The solution to holding more boost and maintaining driveability with the 1g is to compress the springs that release the valves, by taking a 2x4 piece of wood and a hammer and banging it down by force, or slipping a nickel over the hat and placing it into a vise grip to compress the springs. At this point the JDM MR BPV can hold 25psi safely maybe to an upwards of 26psi if you're lucky and the "crush" was done well. Crushed 1g maintains the best drivability and doesn't sacrifice finances and dependabilty IMO, anyhow, it sure beats spending 200+ on a BOV, and the recirculation type will not throw off your MAF, which generally results in running rich and poor idle.
I haven't seen many scoobies run 30+psi, that's pretty extreme.... But any type of VTA BOV with a tune will hold just fine.
Old May 20, 2005 | 02:59 AM
BuLocal's Avatar
Aps
Old May 20, 2005 | 03:17 AM
plokivos's Avatar
tial or forge.
forge is cheaper but tial's sick.
Old May 20, 2005 | 07:33 AM
Mr. Slappy's Avatar
i've got hks ssqv and holds boost great and sound is a plus
Old May 20, 2005 | 07:37 AM
djmikeymike's Avatar
APS.......i think it is one of the only BOVs that doesn't need any adjustments to work perfectly
Old May 20, 2005 | 07:38 AM
DEL TURBO's Avatar
APS dual vent works great. No leaks and no part throttle issues.
Old May 20, 2005 | 07:45 AM
Warrtalon's Avatar
I'm sorry, there's no way in hell you know people running a crushed 1g BOV with 30psi and no leaking. I read the example you gave, and I understand the process, because I used it on my 12.1-sec 1g, and the crushing worked beautifully. The problem is you can only crush it so far, and in no way, shape, or form could it hold 25psi, much less 30psi after being crushed all the way. This was my original BOV, so it's always possible the spring had worn over time, but I did this on 3 separate BOVs with the same result. I didn't test mine by just slapping them on and running whatever boost I wanted, but rather by using a psi gun. I would squeeze the trigger at 21-22psi, and the valve would start to open. Anywhere below this, and it wouldn't open, showing that it would not leak. Anything above it made the valve open easily. If anyone else has empirical evidence that the 1g BOV can hold 30psi, please show me. I'd love to be wrong, because then I'd just go put one on my MR.
Another important thing to know is that once you crush it, you can't go back. You will get compressor surge all the time, because the valve won't open to release the boost pressure unless you get all the way up to the max psi. For example, if you are only running 19psi on the street for daily driving, you're going to get compressor surge all the time, because the BOV won't open below 22psi or whatever.
