Battery
Old Feb 14, 2003 | 01:35 PM
OnlineAlias's Avatar
Battery
Was just looking at the new C&D which clearly shows the battery being mounted in the front of the car. In 2 seconds that could be moved to the trunk for better weight distribution. Wonder why Mitsu didn't do this from the factory (cheap, no warranty issues, huge change in distribution, AND more room for cold air gizmos)? Comments?
Old Feb 14, 2003 | 01:39 PM
yannotmi's Avatar
Just wondering how 12-15 pounds can help weight distribution?
Old Feb 14, 2003 | 01:41 PM
chronohunter's Avatar
That's a thirty pound net change for the better and lower too, It would be a worthwhile mod. We need a vender with a affordable kit
Old Feb 14, 2003 | 01:45 PM
A LEAD acid battery? That thing is more like 50 pounds. It is not uncommon for them to be in the trunk, BMW and the like have been doing it for years. M3's have 50 50 distribution (battery in back), and the EVO desparately NEEDS help with its 60 40.
Old Feb 14, 2003 | 01:46 PM
Right on, cables and a mounting block...what a cheap mod for huge gain.
Old Feb 14, 2003 | 01:47 PM
yannotmi's Avatar
Ok I doubt 50lbs. If so concerned relo a dry cell to the trunk, very easy and you don't have to worry about venting.
Old Feb 14, 2003 | 01:52 PM
Ok, maybe 30 is closer...(I come from an M3 with a huge battery), but still
Old Feb 14, 2003 | 01:54 PM
yannotmi's Avatar
Oh I hear ya, make one. All you need are some posts and some mounting bracket. Run like a 2 or 0 Gague from front to rear and ground in the trunk. Easy mod. Someone will charge like $200 for a kit.
Old Feb 14, 2003 | 01:55 PM
Moroso sell a battery box with vent (check Summit or someone like that), most modern batteries are sealed anyway. You need A very large guage cable, a 2guage (or so) and about 15ft of it assuming you can ground it it the back, something like that.
We need some one to corner weight the car and tell us which side to put it on
HobieKopek's Avatar
Kits are universal. Get one from Summit Racing with box for like 45 bucks.
W/ red box Part #SUM-G1199 $42.95.
Our Summit trunkmount battery kit has everything you need to move your battery: red polyethylene marine battery case, case straps, 20 ft. of positive cable with connectors, 3 ft. of negative cable with connectors, H-bar battery clamp, two rubber grommets, and cable straps. It's the easy way to transfer battery weight or clean up your engine compartment.
Old Feb 14, 2003 | 01:57 PM
yannotmi's Avatar
One example
I would never pay that but wanted to post the kit
Old Feb 14, 2003 | 02:00 PM
Just for fun I went out and weighed a medium sized car battery (I'm not crazy, everything was already out there to do it real quick )
THE VERDCT:
45 pounds!
Old Feb 14, 2003 | 02:01 PM
yannotmi's Avatar
Guess I am dumber and stronger than I thought. Very deceiving.....
Old Feb 14, 2003 | 02:10 PM
That Summit kit is the go...all it needs is a Ralliart sticker and we can resell them for $200 (don't tell anyone It'll be our secret )
Old Feb 14, 2003 | 02:12 PM
Ok, first mods when I get the car:
Get AAA membership. (for tows if I get a flat)
Take Spare out.
Move battery.
