Headlight problem
Old May 22, 2005 | 09:06 PM
Ironwolf's Avatar
Headlight problem
Blinkers and fog lights not working on HID headlights.
What is the most likely area to look for the problem ? Thanks
Old May 22, 2005 | 09:08 PM
03BREvo8's Avatar
loose connection?
Silver05Bullet's Avatar
Check the fuses
Old May 22, 2005 | 09:12 PM
Ironwolf's Avatar
Troubleshoot
Is there anyone in Jersey that can help me find the problem.
I will have the car in my backyard this week.
DCSilvrEvo's Avatar
bulbs if high mileage.
Old May 22, 2005 | 09:23 PM
Ironwolf's Avatar
Bulbs
I will check all bulbs first for continuity.
Car was in a accident all body work done, just the light problem left.
Hid's working.
Old May 22, 2005 | 10:49 PM
bukhumnoi2000's Avatar
I would definitely 1. Check Fuse 2. Check light bulbs 3. Check wiring, make sure they're plugged it during repair if disconnected 4. Switch ... in that order.
Old Jun 1, 2005 | 05:05 AM
Ironwolf's Avatar
Progress
Got the car from the body shop saturday. grinding in the back wheel.
One caliper bolt not tightened all the way down.
Checked the fuses under the dash and hood, all seem good.
How do you pull out the twin fuses in the yellow square box.
There are other relays ,Etacs-ecu in the fuse box. Is there anyway to check ?
Kealinstillz
Sep 17, 2015 09:20 AM
gieri002
Sep 16, 2010 07:23 AM
Shingen
Lancer Troubleshooting
May 20, 2007 10:04 PM
modelchris
Mar 12, 2005 07:39 PM
psmokie68
Sep 1, 2004 02:15 PM
