Problem with Greddy Bov
Old May 26, 2005 | 04:17 AM
  #31
krafty's Avatar
Originally Posted by ct9a gsr
You can goto the dollar store and purchase a typical coach's whistle for real cheap... and zip-tie it onto the openning of your type-s and then put the re-circ hose on it. You'll get a pretty loud whistle and it shouldn't stall too much.
haha
Old May 26, 2005 | 03:19 PM
  #32
BlueEvo04's Avatar
Originally Posted by invazn
BlueEvo04
What I do to make the noise a little louder than now?
it will hurt your car performance if not recirculating.single spring is to soft sometime i get the flutter.it's better with both spring on.sounds about the same.
It's alreayd came with the recirculating and I also have the AEM short ram intake.
Old Jun 5, 2005 | 05:55 PM
  #33
wprettyboy's Avatar
i have both springs in and mine is fluttering bad, i have it turned in about 5 turns past first contact. is that to much or not enough??
Old Jun 5, 2005 | 05:58 PM
  #34
Jakeg97's Avatar
not enough, then keep tightening
Old Jun 5, 2005 | 06:25 PM
  #35
95GSXtoEVO8's Avatar
flutter = to much tension
you will need to back it out some, if that doesn't work, the single spring mod will get rid of the flutter.
Old Jun 5, 2005 | 08:13 PM
  #36
ozrally05's Avatar
alright maybe you should get it vented to atmosphere more pressure better the sound.. buschur offers special parts for doing that if you live in ohio take a drive there or order it... im sure that would fix ure problem, but maybe you can call them and see what they say...
Old Jun 5, 2005 | 09:03 PM
  #37
djmikeymike's Avatar
i think if you what it louder you might need to replace your DV with a Turbosmart or APS DV/BOV.....
http://www.airpowersystems.com.au/us...o/bov/blow.htm
or
http://www.turbosmart.com.au/
Old Jun 5, 2005 | 09:05 PM
  #38
double post.... sorry
Igaly1021
Jun 12, 2016 05:52 PM
Bergen Automotive
Aug 5, 2010 10:41 AM
HondaFlyBy
Oct 7, 2007 01:23 PM
HondaFlyBy
Oct 7, 2007 02:36 AM
bmaga123
Apr 30, 2005 02:05 PM
