double clutch shift
Originally Posted by dizzigital
i think double clutching is everything you just said except you flutter the gas pedal while in neutral before clicking into the lower gear.
double shifting is what it sounds...you push the clutch twice
once to go in neutral, and again to shift to a lower gear after you have slowed down while in neutral (when you switch to a lower gear, you have the option of rev matching, but the act of rev matching is not what makes it a double clutch)
instead of going from 4th to 3rd, which is a regular downshift, you go from 4th to neutral to 3rd (again, rev matching as you please)
Originally Posted by pb24dagrk
i'm sure you meant power shifting
double clutching is used only when slowing down (let's say you are crusing in 4th and want to slow down, you depress clutch, put in neutral, brake and slow down, then depress clutch again to put it to 2nd..... vs. braking while in gear and then downshifting)...correct me if i'm wrong
it was misused in fast and furiousl (lol) just because it sounds cool like you are double shifting super fast haha
Originally Posted by Mivo
isnt that called head-toe or whateve? i forgot the name but its when you blip the throttle as you downshift very similar to power shifting.
power shifting is you shift gears at wide open throttle without letting off the gas pedal at all
HEAL-TOE shifting is being able to downshift while braking at the same time (all in a simultaneous and quick action)...it's very hard to do and you need a lot of practice
picture yourself downshifting as you approach a turn, but you want to brake at the same time.....you can't do it unless you (a) have 3 feet, or (b) use heal-toe method
with your right foot blipping the throttle to rev match, your left foot turned to the left and left heal begins to depress the brake, while in that same motion your left toes depress the clutch....so at the same time you're pushing the clutch, braking, and blipping the throttle to rev match
Originally Posted by fshwcrs
double clutching is when you are in gear, clutch in, put it into neutral, clutch out, blip throttle, clutch in, put it into the lower gear, clutch out. its pointless though, because transmissions have synchros now, so youre wasting time by doing all the extra clutch work and shifting when you should be concentrating on braking and your line.
it is actually very useful if you are looking to conserve your clutch and don't mind using your brakes that much more.
it's something i like to keep in mind right now because i'd rather spend $400 on some new brakes than a grand on a new clutch.
i don't track yet, so it's not a waste of time. this is actually ideal for me. i also enjoy the smoothness of acceleration when dropping down a gear while using this method.
no, that's just rev matching WHILE double shifting
Originally Posted by DCSilvrEvo
Uhh I thought double clutching is when you do a complete down shift, depress clutch and rev then let clutch go. IS that correcT?
double clutch/shifting:
4th gear
clutch
neutral
let off clutch
brake
clutch
3rd gear
regular downshift:
4th gear
clutch
3rd gear
You guys are right, double clutch shifting is used when down shifting. The idea is to be able to allow your engine and transmission to catch up to the speed of the wheels.
The modern transmissions have almost eliminated the need of the double clutch technique when downshifting due to the syncros, but there is still an art to the rev matching.
When down shifting, let's say from 4th to 3rd, if you were to just depress the clutch, shift to 3rd and release the clutch, the engine speed would have to catch up to wheel speed due to the lower gearing. This will cause the car to decelerate and put an unnecessary load on the engine and transmission. Double clutching can eliminate this.
(the following 2 examples assume that you are not trying to decelerate, just trying to down shift...)
Here's how it goes...
HOWEVER...
Like was said earlier in this thread, the modern syncros have eliminated the need to match the transmission rpms to the wheels so all you have to worry about is the engine. This means the double clutch technique is not required so the process is easier. The rev matching still needs to occur for the motor but there is no need for the shift to neutral and release of the clutch.
It would go more like this.
Performing these techniques while braking is another story. That will require a little heal-toe action between the brake and the accelerator.
- While in 4th, push in the clutch and shift to neutral, then release the clutch.
- While in neutral tap the accelerator to raise the engine and transmission rpms.
- Then push in the clutch, shift to 3rd and release.
HOWEVER...
- While in 4th, push in the clutch.
- While shifting to 3rd and with the cutch still depressed, tap the accelerator.
- Release the clutch.
no, that's rev matching...you rev match when yuo downshift
dont try working the clutch and brake with the same foot, at least when theres stuff around you to run into or run into you. the brake and gas are modulated with the same foot, and the other foot works the clutch.
heel-toe'ing isnt hard at all.
i knew i had something wrong...all this typing and thinking got me confused this late at night, haaha
i'm too uncoordinated
precisely as i thought. the fluttering allows a smooth entrance into the lower gear.
downshifting like this is using the engine to help braking, but its mostly so youre already in the right gear coming into the turn, letting you power out of it. this isnt saving your clutch any unless you were dragging it out to slow you down, which is a horrible habit no matter what.
I agree with double clutching is not needed anymore, but at least the mad scientist doesnt need to rip apart my block, and fix the piston rings i fried *OHHHH's in the backgroud*
Side note: its sad, but i bet everyone knows at least one line from that movie (shutter)
