What Brand (10-30) Oil Do You Use And Why?
Old May 27, 2005 | 02:18 AM
  #91
evo81's Avatar
i was to late to throw in my say i bet there was some good replys before the mod stepped in
Old May 27, 2005 | 03:00 AM
  #92
xxxevo8xxx's Avatar
I own a mobil service station and i run Royal Purple 10W-30 in my car. I used to run the mobil 1. When switch from mobil to royal purple there was about a 20 degree drop in the oil temp. The mobil 1 does not compare to Royal Purple. I would run royal purple!!
Old May 27, 2005 | 04:34 AM
  #93
rsr14's Avatar
Mobil one. I used some 20/50 shaefer once, didn't think it would be any big deal with the different viscosity but the lifters were definately more noisy. Went back w/ the 10/30 and all was good.
Old May 27, 2005 | 04:46 AM
  #94
Event-Horizon's Avatar
Originally Posted by HuskerEVO
BTW, I still haven't heard from you w40 guys... Why use it? Longevity over performance??? or what?
I use Mobil Delvac 1 5w-40 because it is has excellent used oil analysis with low wear numbers. It also has the benefit of fast flow on start up. I also use it because I live in Georgia where it gets in the 90's during the summer and I can benefit from slightly thicker oil. Delvac is also less likely to shear and fall out of grade like other oils. The EVO service manual states that you can go as high as a 20w-50 in hotter climates. I have also not seen a decrease in my gas mileage while using Delvac. This oil is also made for high stress diesel engines with extended drain intervals so I know this oil will withstand the beating that a 4g63t motor will through at it.
Old May 27, 2005 | 06:46 AM
  #95
HuskerEVO's Avatar
I can certainly appreciate that. It's just interesting and refreshing to hear from people who aren't as concerned with performance as they are engine longevity. I'm not entirely convinced a heavier weight oil will actually provide better protection in hotter weather considering the good synthetics are rated for extreme temps before thermal breakdown.
Most of the reviews and tests that I have seen all seem to indicate very little difference between the modern w30 and w40 synthetics (weight wise not cold start). Can you guys point me to anything that would show some real world advantages to running a heavier weight oil?
BTW Event Horizon, you said you haven't seen much of a decrease in your MPG. What kind of mileage do get?
Old May 27, 2005 | 07:22 AM
  #96
theblue's Avatar
Wolf head recycled oil..... j/k I use mobil 1 5w30
Old May 27, 2005 | 07:44 AM
  #97
WildRice's Avatar
Mobile 1. I use it because it is relatively cheap and I change it every 6 months (I have 22k on my "03"). I usually compare oils based on my fuel consumption. When I switched from Castrol GTX to full syn. I gained almost 2 MPG. When I bought the EVO, I went over to M1 and have not observe any differences.
Old May 27, 2005 | 07:57 AM
  #98
Depending on how I am driving, I usually see around 18-21MPG in town.
Back to what you were asking though. Oils with higher viscocities usually protect the lower end of the engine like the bearings. However, if the viscocity is too high, you can increase the wear in the valve trian. The trick is to find an oil that will protect the whole engine. Thats why its usually best to stick with what the manufacture suggests. For example, people who live in climates that see temps below freezing, its best to use a 5w-30. For milder climates where temps bump 32F they are best to use a 10w-30. I belive in the service manual, if you live in very hot climates you can run a 20w-50. I use a 5w-40 because it is a great in between oil. It can get both very cold and very hot in Georgia. Also, most other countries run a 5w-40 or heavier in the EVO.
Also, you have to understand that 5w-30 and 10w-30 are recommended usually because of the government and fuel economey requirements. It just doesn't mean its the best for your engine.
Good Thread for reference:
http://www.lancerregister.com/showth...threadid=61489
Old Jul 11, 2005 | 03:36 PM
  #99
hawjdude's Avatar
i justed put in some castrol 5w20, because i couldn't find any 5w30 at wal mart. I'll try the german oil 0w30 next time.
Old Jul 11, 2005 | 03:42 PM
  #100
kyJelly's Avatar
mobil one
Old Jul 15, 2005 | 02:02 PM
  #101
vanisher's Avatar
Amsoil in all my cars with mobil 1 filter.
Old Jul 15, 2005 | 02:09 PM
  #102
Spec'd's Avatar
MOBIL 1 ONLY !
- Biatches
Old Jul 15, 2005 | 03:12 PM
  #103
grcygetr's Avatar
Mobil 1 synthetic: works great :-)
Old Jul 16, 2005 | 02:59 PM
  #104
DragNRacing's Avatar
Mobil1 10w-30
Old Jul 16, 2005 | 05:02 PM
  #105
EVO-8-Nate's Avatar
Mobile 1 10w-30 with mobil 1 filter.
-Nate
