BOV and Intake
Old May 30, 2005 | 02:26 PM
Mitsulancerrox's Avatar
BOV and Intake
I recently installed a new intake for my buddy who owns an evo and he now wants to put a BOV on it. What are the best choices for BOV and what do i need to install it? A new upper IC pipe? special flanges?? Anyone have ideas
Old May 30, 2005 | 02:57 PM
djmikeymike's Avatar
it depends on the BOV.........APS, Turbosmart and the JDM MR take about 10 mins to install and if you do some searching you will find that this are the best ones for the EVO
Old May 30, 2005 | 03:01 PM
lilman8403's Avatar
i agree, The MR BOV will be easy to install and you will benefit from it instead of just hearing the sound. The mR BOV seems like it creates more boost at high gears. Just my two cents. Don't bother with and aftermarket BOV untill a new intercooler is in the budget.
Old May 30, 2005 | 03:04 PM
could you explan you logic here???
you should only VTA if your not useing the MAF sensor and you should upgrade your VTI BOV when you are running higher the stock boost levels..
Old May 30, 2005 | 03:10 PM
ct9a gsr's Avatar
It is not possible for a BOV to create boost.
I do not see how a new intercooler is required for an aftermarket BOV.
Old May 30, 2005 | 03:11 PM
Zeke1982's Avatar
Hi... this might be out of topic.
If you change your intake and bov is the warranty going to be void?
How about if i change it back to stock? are the dealer going to find out that i did change the intake and bov?
Thanks
Old May 30, 2005 | 03:13 PM
ddubb's Avatar
the greddy type-s bov with bolt on flange...do the single spring mod and you're set. Installed mine in 15 mins. do some searches but i haven't had any issues with my setup and read a lot of good reviews on fully recirc and single spring mod. hope this helps
Old May 30, 2005 | 03:15 PM
ddubb's Avatar
zeke1982, i think it depends on the dealer you are going to do warranty work at. you can always go back to stock so that you don't have to deal with hassle and i don't think they would be able to tell b/c they are all bolt on parts.
Old May 30, 2005 | 03:17 PM
lilman8403's Avatar
sorry, all i meant to say by that post was that for the money and the peformance the MR BOV works great for me. As far as the aftermarket intercooler, I meant to sy the piping because it looks much cleaner when the flange is welded to the piping.
I didn't mean to sputter out the wrong words.
Old May 30, 2005 | 03:19 PM
Thegame's Avatar
Thanks
I am running an MR BOV and Hallman MBC with the stock intake. I take it all off for my all of my dealership visits. (No I'm not shady, I'm just playing the same game they do.) There is no way for them to tell that you changed something out, unless you put it on wrong or something like that. You'll be fine taking it off. You may have a hard time with the MAS though.
Old May 30, 2005 | 03:22 PM
lilman8403's Avatar
my dealer doesn't say much and i have full exhaust, MR BOV, And i had a reflash.
Old May 30, 2005 | 03:24 PM
Zeke1982's Avatar
Thanks a lot man.. The reason why i asked this question because i'm going to buy this evo He asked for 21750. It a 2003 and has 20k millage. but he does not have the stock parts.
He also have an aftermarket stereo. are they going to void the warranty for the stereo? by the way is this a good deal? Thanks for your input man I really apriciate it.
Old May 30, 2005 | 03:30 PM
lilman8403's Avatar
sounds like a good deal. What color is it? No the stereo definatley will not be a problem.
Old May 30, 2005 | 03:35 PM
ddubb's Avatar
zeke...i would look at some websites like edmunds and cars.com just to verify the balpark range that the evo with xxxxmiles would sell for from a private party. Also, just with my 05 evo the info states that the 10,000/10 yr. waranty is dropped to 5 yr/50,000 when transfered title. I don't know how the other model year waranties work, just something to maybe call a dealer to see how much warranty you will have, most cases the remaining warranty is just handed over to new owner.
I don't think you have to worry at all about an aftermarket stereo at all. that has no bearing on the engine/performance characteristics of the car and should not void anything. I've never had or heard of any issues there.
If you want to find stock parts to change back for dealer visits you can look on the private for sale forums, I've picked up a few parts there too
Old May 30, 2005 | 03:36 PM
ddubb's Avatar
I wish i lived closer to you so I can hit up your dealer. alot of bull**** dealers around chicago, won't do warranty work
