272's installed boost went down
Old Jun 3, 2005 | 09:01 PM
ThEHiTMaN's Avatar
I have noticed that my boost has gone down since I installed my 272's is this correct? I was peaking in the high 23's now in the mid 22's also was holding 20ish to redline now i am only holding 18-19.... Should I crank it up a notch?
Old Jun 3, 2005 | 10:33 PM
rlazer5000's Avatar
Boost is gonna go down because the higher lift intake cam decreases vacuum pressure. I would recommend getting a tune before turning up the boost.
Old Jun 4, 2005 | 05:59 AM
Iceman2011's Avatar
^ true
Old Jun 4, 2005 | 06:10 AM
rraulston's Avatar
the longer you keep the valves open, the more boost that goes into the cylinders, the less pressure is measured in the intake manifold. Thus a lower reading. Make sence?? Cranking it up with out logging AFR and knock could be risky. I would advise you tune it.
Old Jun 4, 2005 | 08:38 AM
nolimits1320's Avatar
264's dropped my stock boost to 13psi.
Old Jun 4, 2005 | 10:43 AM
Evo348's Avatar
would reflashing the ECU fix the idle that the 272s give the car? Or it wont help?
Old Jun 4, 2005 | 10:49 AM
rlazer5000's Avatar
A reflash will help, and also the use of adjustable cam gears.......both will give u a stock like idle.
Old Jun 4, 2005 | 11:42 AM
ThEHiTMaN's Avatar
I might just invest in a Wideband and tune it myself.
