Water Wetter results
Old Jun 14, 2005 | 12:45 PM
k270kmh's Avatar
Question Water Wetter results
Does the Water Wetter really works?
Does the Water Wetter harm the temperature sensor?
I put one bottle and couldn't notice a decrease in the temperature.
Old Jun 14, 2005 | 12:48 PM
eling99's Avatar
subscribe
Old Jun 14, 2005 | 01:54 PM
jbfoco's Avatar
I ve used watter wetter for as long as i can remember and it works!!
We did a test at my old shop with my mx race quad its a honda trx 250r with an esr 310 kit.
I installed an esr temp gauge and tested wetter wetter/ distilled water vs colant/distilled water.
Temp varied 12-20 degrees cooler with water wetter
Old Jun 14, 2005 | 02:01 PM
k270kmh's Avatar
nice to hear this...
Have you ever heard about coolant sensors problems after WW?
Old Jun 14, 2005 | 04:05 PM
fowler259's Avatar
I have used water wetter for the last 4 years in my race bikes and have never had any sensor problems. It works well in my book.
Old Jun 14, 2005 | 04:15 PM
nils's Avatar
I have used water wetter for the past 4 years with great success.
n
Old Jun 14, 2005 | 06:53 PM
tasco's Avatar
Can someone tell me what water wetter is? Is this water injection?
Old Jun 14, 2005 | 06:55 PM
nils's Avatar
http://www.redlineoil.com/products_coolant.asp
Old Jun 14, 2005 | 08:04 PM
plokivos's Avatar
just can't use it during winter
Old Jun 14, 2005 | 10:14 PM
naucrx's Avatar
Hmm, I should try this stuff out. There is no winter here, we just have 2 seasons: Hot, and not quite as hot.
Old Jun 14, 2005 | 10:29 PM
smp3000's Avatar
I haven't put it in the evo yet- but it's worked GREAT in my other cars. Defintely a noticeable difference in Temp.
Old Jun 14, 2005 | 10:33 PM
DCSilvrEvo's Avatar
So Basically the engine runs cooler with this substance? Ive seen it @ Advance Auto so how much do i use and everything?
Old Jun 15, 2005 | 08:23 AM
Evo8nut's Avatar
There is no Con at all to using this in our evo's?
Old Jun 15, 2005 | 08:36 AM
PA-silver03evo's Avatar
The engine will still run the same temp due to the thermostat doing its job. The thermostat is still what regulates coolant temp and it will still open at the same temp. Water Wetter is just supposed to give better protection. If you didnt have a thermostat and the coolant temp was just allowed to get as hot as it can, it would be cooler with Water Wetter. At least according to Redline it would.
On a side note, running cooler is not necessarily a good thing. Cars are made to run at the temp they run for a reason. If its too cold, you will get sludging in the engine among other problems. If the car would perform better when colder, Mitsu would have made it run cooler.
Old Jun 15, 2005 | 08:40 AM
DCSilvrEvo's Avatar
Good Points. Thats why we warm our cars up duh.
I wonder how it would work with the ralliart themostat?
