Custom Lower Arm Bars for Invidia Downpipe!
Old Jun 14, 2005 | 07:20 PM
TURBODAWG's Avatar
I just got an Invidia downpipe and found out that neither of the lower arm bars will reinstall after the downpipe installation. After determining that the Cusco V1 or V2 wont fit, from vendor recommendations, I decided to design my own. I needed 6 washers under the factory front (3 bolt hole) bar to get it to fit. On the rear, I needed 4 washers. Each washer is about 2 millimeters in thickness.
With these measurements, I decided to draw up two bars on CAD that would work.
Here are some of the pictures of the bars alone and then mounted to the car. They are constructed out of solid aluminum bar.
Weight on the rear bar:
Stock 1.2 lbs
New Aluminum bar 1.6 lbs
Weight on the front bar
Stock 1.4 lbs
New Aluminum bar 2.0 lbs
I ended up adding 1 lb together with the new bars even though they are aluminum instead of the factory steel tubing bars.
Here are some pictures:
Brian
Old Jun 14, 2005 | 07:22 PM
TURBODAWG's Avatar
Picture Installed
Heres another
Old Jun 14, 2005 | 07:23 PM
TURBODAWG's Avatar
Another installed Picture
Another
Old Jun 14, 2005 | 07:24 PM
TURBODAWG's Avatar
Another
Another picture
Old Jun 14, 2005 | 07:27 PM
TURBODAWG's Avatar
One more
I am done..
Old Jun 15, 2005 | 07:08 AM
TURBODAWG's Avatar
BTW,
Specifics: These bar provide 1/2" of additional clearance on the front bar and 3/8" of additional clearance on the rear bar.
Brian
Old Jun 15, 2005 | 07:44 AM
genrec's Avatar
good job.
Old Jun 15, 2005 | 10:44 AM
TURBODAWG's Avatar
Thanks.
Old Jun 15, 2005 | 10:51 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
nice man!
Old Jun 15, 2005 | 11:05 AM
JeffR116's Avatar
How about fabricating up some sets for your fellow EvoM members?
I'm not picky about them being aluminum. Since they're on the bottom of the chassis, steel will work for me.
Anyone else interested?
Jeff
Old Jun 15, 2005 | 11:17 AM
TURBODAWG's Avatar
Evodave: Thanks!!
Sending the prints off to a machine shop to get them quoted. I might consider getting some made if they interest was there. Would anyone else be interested in these? The higher the quantity, the lower the cost.
Aluminum is quite a bit more expensive than steel.
Steel would be cheaper to make them out of but heavier.
Brian
Old Jun 15, 2005 | 11:27 AM
Russell K's Avatar
I would be interested in a set if you make them in aluminum? Maybe you can find someone to powdercoat them also? Or do we have someone here on the board that could powdercoat them?
-Russell K
Old Jun 15, 2005 | 11:31 AM
TURBODAWG's Avatar
I know a place that will powder coat them not too far from here. I sanded with 220 grit sandpaper, 2 coats or primer, and 2 coats of high temp engine enamel. A little time consuming, but they look pretty good.
I will wait to hear from the machine shop to see what I can sell them for.
Brian
Old Jun 15, 2005 | 03:47 PM
Monkey's Avatar
I have the invidia dp and test pipe and both of my stock lower arm bars are on. The front is just a tad slanted, but it's still on.
Old Jun 15, 2005 | 03:55 PM
antonio010's Avatar
Thats awesome, keep us posted!
