Greddy turbo timer doesnt work?????
Old Jun 16, 2005 | 05:13 PM
CArkid0101's Avatar
I installed my greddy turbo timer today. Only problem is when i shut the key off to ACC it keeps the car running. But when i go back to lock to take the key out the car shuts off.
It is grounded, good. greddy says its not neccesary for the ebrake thing to be pluged in
My windows dont work on acc either, they nenver did, even before the install.
I do have the plug and play harness connected to what i believe is right.
HELP ME!!!!
Any ideas?
Old Jun 16, 2005 | 05:15 PM
quiksilverevo26's Avatar
do you have the plug and play???...if so check your connections and ground wires again...
You shouldn't have a problem with it shuting off like that
Old Jun 16, 2005 | 05:20 PM
CArkid0101's Avatar
I do have the plug and play adapater.
When i turn the key off the turbo timer says "OFF" so it's not like its just dying.
Old Jun 16, 2005 | 05:25 PM
I have the same TT with the adapter and I have no problems when I installed it. My best guess if you plugged it up correctly, than your ground wire is not ground well. The same thing happend to my buddies evo when I installed his blitz TT with adaptor...Try messin with the ground, if that doesn't work then i don't know.
Old Jun 16, 2005 | 05:28 PM
CArkid0101's Avatar
If it turns on it can't be the ground.
Old Jun 16, 2005 | 05:31 PM
actually it will still turn on, but it won't work correctly...
Old Jun 16, 2005 | 05:36 PM
CArkid0101's Avatar
Im pretty positive that if electronics aren't grounded they wont work at all.
Old Jun 16, 2005 | 06:09 PM
okay, just trying to help you out...especially since that's the exact thing that happened to my buddie...
Old Jun 16, 2005 | 06:11 PM
plokivos's Avatar
should of gotten hks, proven to work.
and yes, if you don't ground it, it wont turn on.
your e-brake harness isn't hook up. that's your problem. Now go fix it.
it's the blue e brake wire.
Old Jun 16, 2005 | 06:12 PM
Robert_K's Avatar
Just curious... You don't have the harness?
Old Jun 16, 2005 | 06:13 PM
Robert_K's Avatar
Duh! Didn't even think of that! Good catch!
Yeah! Go check to make sure your e-brake harness wire is hooked up.
Old Jun 16, 2005 | 06:24 PM
okay let me clearify this...don't want this to become an arguement. If the ground wire is "improperly" installed (meaning not a good metal to metal contact) then it will not work properly. I do have the harness and had no problem with it. My buddie was the one with the grounding problem...same symptoms as you, it will turn on but when it took the key out then the car will turn off and it will say "OFF" on the TT. After alot of testing it my friend and I did, we found out it was the ground...we found a better ground for the wire. Hope this works...if not just go back to where you bought it. Might be a bad one
Old Jun 16, 2005 | 06:31 PM
CArkid0101's Avatar
are you serious, thats why?
i went on the same ground it says to on the install on this site. the bolt behind the radio. i tightened her down real good. The reason it turns off is the e-brake harness, no lie?
Old Jun 16, 2005 | 07:23 PM
Robert_K's Avatar
I had the HKS... With the HKS you hooked up the blue wire to the e-brake lead. This way when when the e-brake is released during count down (ie someone trying to steal your car while its running) it would turn off the timer, shuting the car down.
Old Jun 16, 2005 | 08:16 PM
CArkid0101's Avatar
the greddy does the same but doesnt say its needed. i just want it to work period i tried different grounds...same, also, my windows or sunroof dont close on just acc, do any of yours?? there may be a different problem
