need help with stock wheel lock
Old Jun 17, 2005 | 02:15 PM
03SilvaEvo's Avatar
I can get all of them off but one. Damn wheel lock key doesn't want to bite ! I think the wheel lock pattern is slightly deformed so maybe thats why its not biting. Any suggestions?
Old Jun 17, 2005 | 03:06 PM
SR20DE-T's Avatar
take a socket that is a little tight and hammer it in to jam it in the socket and open it. That is the easiest way of doin it.
Old Jun 17, 2005 | 03:13 PM
grcygetr's Avatar
How about the Gator grip socket?
http://gator-grip.com/
Old Jun 17, 2005 | 03:18 PM
Thegame's Avatar
I almost had the same problem last time I rotated my tires. If the wheel lock key itself is deformed, you can order a new one. If the lug nut wheel lock is messed up, good luck as I have no idea how you would ever get it off. If it's a factory Mitsubish part them you should take it down to the dealer and make them get if off for you.
Old Jun 17, 2005 | 03:19 PM
MeKilla's Avatar
had the same problem, i fixed it with a hammer and a 3/4" socket...
edit: then I had mitsu buy my 4 new locking lugs.
Old Jun 17, 2005 | 03:20 PM
webguy330i's Avatar
Also your dealer has a master key set of lock sockets; you can swing by and 'borrow' them if need be.
Old Jun 17, 2005 | 07:29 PM
Aikido's Avatar
this is usually located where your spare is and your jack right?
Old Jun 17, 2005 | 07:48 PM
chaotichoax's Avatar
like a few others said..... use a normal socket and tap it on there you'll be able to get it off I had to do it on a car in my auto class not exactly the best method but it works.
Evodetailer123
Dec 1, 2016 07:34 AM
EvoCop
Jun 23, 2009 09:20 PM
bbenavitz
Sep 19, 2008 12:37 PM
k270kmh
Nov 17, 2007 04:20 PM
Thoe99
32
Jan 11, 2005 01:29 PM
