Engine Longivity
Old Jun 19, 2005 | 10:04 PM
Aikido's Avatar
Engine Longivity
just curious with more mods then just a few bolt-ons (intake, exhaust, Bov) how much reliabiltiy do u lose in your powertrain. I use my evo as my daily driver. So my questions is if i get reflashed or even get cams and gears. What kind of life out of the engine am i to expect. Now i'm not talking about clutches or TC just the engine and the tranny in general. TIA
Old Jun 19, 2005 | 10:15 PM
bluebanana23's Avatar
keep in mind that the car is relatively new so don't expect much of an answer. One person has gotten over 60K but I believe he was close to being stock so that doesn't help much
Old Jun 19, 2005 | 10:18 PM
SJ EVO 8's Avatar
hope and pray for no crankwalk on these cars after 100,000 miles.2nd gen mitsubishi eclipses and talons suffered from this problem.
Old Jun 19, 2005 | 10:29 PM
LEVIII's Avatar
Has any crank walk happened to an evo yet?
Old Jun 19, 2005 | 10:33 PM
white05evoVIII's Avatar
i believe that has taken care of this problem. i could be wrong though i am just relaying what i heard. as far as longevity goes, as long as you don't beat up on it everyday and you drive like a sane person most of the time you should be fine for a good while.
Old Jun 19, 2005 | 10:34 PM
TwoMix9900's Avatar
put it this way...the car will treat you the way you treat your car...'nuff said
Old Jun 19, 2005 | 10:51 PM
Gary Bechtold's Avatar
It's not the same 4G63. The 2G 4G63 was more along the lines of an EVO III motor. It is built tougher in the EVO VIII and responds to mods even better than it did in a DSM. But if you abuse any motor it will eventually come back to bite you.
Old Jun 19, 2005 | 11:54 PM
Devbo's Avatar
i agree with two mix. you will get as much out of your car as you put into in. with that beings said there are alot of mods that you can do to gain alot more time in your turbo and your engine. get an oil catch can. awsome mod for practicallity and good dress up mod. i think that biggest and the best main. mod is the turbo timer i hated sitting in my car waiting for it to cool down.
Old Jun 19, 2005 | 11:58 PM
SilverEvo8owner's Avatar
53,000 miles. Stock clutch, i've got cams, plenty of other mods. it's been to the drag strip, etc. Doing just fine. No real big problems
That's about all I can tell you. Most of the real high mileage EVOs so far are close to stock.
Old Jun 20, 2005 | 12:28 AM
1.8t's Avatar
No Evo has ever had crank walk problems. That was limited to the 2g DSMs almost completely.
Old Jun 20, 2005 | 12:38 PM
Jakeg97's Avatar
well the evos 4g63 has been around since the early 90s
so i think its safe to say that this engine is the best that mitsu has ever made. and can handle what you want to do to it.
