Wat To Put In Ntercooler Spray
Old Jun 29, 2005 | 07:03 PM
Pete3kGT's Avatar
Originally Posted by plokivos
I put Ice in there, big chunks of it.
That usually mixed with alcohol does the trick for a good day or two.
you could put rubbing alcohol, methanol, water, whiskey, vodka. Something that will evaporate fast as a very cold temperature.
Sung,
Are you serious about the alcohol? I can understand the chuncks of ice, but won't vodka, whiskey, etc damage or clog the spayer nozzles after time. Plus won't that make your car smell like it's a struggling member of AA?
Old Jun 29, 2005 | 07:06 PM
TeamAccolade's Avatar
Not that type of Alcohol.... METHANOL M1 won't freeze ( -144 is freezing temp so i think u'll be alright ) but then its a waste cuz you might as well be injecting that into the engine itself... just use the windshield cleaner. cheap and effective.
Old Jun 29, 2005 | 07:29 PM
mksevo's Avatar
alcohol base fluid is better , which is why they suggest wiper fluid small amount of ETOH . cheap and very clean. rubbing ETOH is better it has a better cooling effect. you would love to spray CO2 this will really lower the temp but its impracticle as a daily use item . distill water is fine but not better than Wiperfluid.
Old Jun 30, 2005 | 02:37 AM
evo_lee's Avatar
I'll stick to DI water, just to be safe. Evo cost too much already.
Old Jun 30, 2005 | 06:25 AM
donour's Avatar
The Water of Life from a drowned Maker.
d
Old Jun 30, 2005 | 06:27 AM
PoorBoys's Avatar
+1
