Intake?
Old Jul 2, 2005 | 06:23 PM
8urv8's Avatar
Intake?
When you have an aftermarket intake on the Evo, does it make a difference if you leave the air scoop on or off?
Old Jul 2, 2005 | 06:35 PM
Thegame's Avatar
This is a good question... By "air scoop" you mean the stock one right? Not the aftermarket hood vent scoop. I elected to leave mine on with my HKS RS but I really don't think it makes a difference. A little more cool air can't hurt.
Old Jul 2, 2005 | 06:36 PM
en1gma19's Avatar
The difference is negligable. It's really just personal preference.
Old Jul 2, 2005 | 06:43 PM
Fa$[- a$ $hi[-'s Avatar
No, it really doesn't matter. That is there to isolate hot engine air from entering the intake air. That and the air box create a tight seal to achieve this.
Aftermarket intakes are a bad idea for turbo engines. Notice on cool and hot days the difference of how your engine performs and reacts. I can really tell the diff were I live. Cooler air into the intake makes my car react so much better (say 70 out) instead of hot days (say 90 out).
If you're wanting to upgrade your intake, I would suggest a K&N drop in filter. Keep the stock air box. Although the stock box may not look as good as a cone filter or what not, it's best for your engine. BTW most cone filters except K&N (and there's another one, I can't remember) do not filter out the dust, etc. good enough (hardly at all).
I put a K&N Typhoon on mine, spent 210 bucks and it killed the power in my car. It was letting too much air in and let the hot engine air right in. There was a huge turbo lag after I put it on. I had to build a custom airbox to isolate the hot from cold and to retard some of the air entering the intake. After this build, all my intake probs went away.
Old Jul 2, 2005 | 08:07 PM
Jakeg97's Avatar
Originally Posted by Fa$[- a$ $hi[-
Aftermarket intakes are a bad idea for turbo engines. .
i like aftermarket intakes
Old Jul 2, 2005 | 08:11 PM
Turbolover's Avatar
well if u have a radiator shroud and u take the air scoop off theres a huge hole underneath. point is leave it on it only helps!
Old Jul 11, 2005 | 05:24 PM
kyJelly's Avatar
leave it on
cold/fresh air is good
Old Jul 11, 2005 | 05:30 PM
Thegame's Avatar
I highly doubt your problems were related to letting in hot air inside the intake. If you think about it, more air vs. cold air pretty much have the same benefits to a certain extent. You're not the first person to have bad experiences with the K'N Typhoon.
Old Jul 11, 2005 | 08:06 PM
unowned's Avatar
Doesn't matter if it's Cold or Hot, the intercooler should be doing it's job...
Old Jul 11, 2005 | 08:10 PM
Jakeg97's Avatar
intake = https://www.evolutionm.net/forums/sh...d.php?t=147111
Old Jul 11, 2005 | 08:13 PM
evokong's Avatar
where air scoop
Old Jul 11, 2005 | 08:44 PM
plokivos's Avatar
i like the stock box but I wish someone would make a box that's bigger than the stock and lighter.
and yes, you need that air scoop to get some colder air in, instead of getting hot air straight from the engine.
Old Jul 11, 2005 | 08:51 PM
en1gma19's Avatar
True, kind of. If the air entering the turbo is cooler it will be denser, meaning the turbo doesn't have to 'work as hard' to make the same boost, which increases it's efficieny. Therefore, it does make a difference. This is why boost goes up 1-2psi during the winter with the boost controller on the same setting.
