My intercooler is takin a beating!!!
Old Jul 12, 2005 | 07:38 AM
05evo's Avatar
I looked at my intercooler the other day and I noticed that its been hit by some little rocks as I was driving is there any way to prevent this, is it affecting my performance or is it okay. is this supposed to happen??? is there a mesh cover of some sort I can put over it????
Thanks for the help.
Old Jul 12, 2005 | 07:39 AM
Tsurara's Avatar
Unavoidable. Don't worry about it, your intercooler will be fine. Putting a mesh screen over it would restrict airflow.
Old Jul 12, 2005 | 07:40 AM
kmcconn9's Avatar
You can get mesh from home dept and cut it to length, deoending on which type you get, it should have smaller holes in the screen. That should help out some, but rocks, bugs and that such are normal wear and tear on a fmic..
Old Jul 12, 2005 | 07:47 AM
evo8silver's Avatar
whats ur intercooler if its the stock yeah thats very normal. once u have an aftermarket one the fins are a lot stronger. the stock has soft fins.
Old Jul 12, 2005 | 08:56 AM
05evo's Avatar
its the stock intercooler, but I don't want it to get dinged up so bad that it does end up restricting air flow or I have to replace it. You think warrenty covers that?
Old Jul 12, 2005 | 08:59 AM
Greg K's Avatar
warrenty's cover mfg defects and installation error. they don't cover normal wear and tear. Kinda like asking if it covers replacing the tires.
ROGERV's Avatar
NO
Old Jul 12, 2005 | 09:01 AM
bbyevo8u's Avatar
how weak is the stock one can it get holes in it?
Old Jul 12, 2005 | 09:03 AM
evo 8 ya's Avatar
you could do two things. One, upgrade you intercooler to a bar and plate style like the one from turbo xs. I have it and it's much more durable than the stocker. Two, I know it's hard but, try not to follow other cars, trucks and 18 wheeler so close.
Old Jul 12, 2005 | 09:04 AM
Late Apex's Avatar
any ic core can get holes in it, but if its just normal road debree then you are fine.
Old Jul 12, 2005 | 09:05 AM
chronozon's Avatar
Here's a good write up by someone on this subject:
https://www.evolutionm.net/forums/sh...rcooler+screen
I bought the exact same mesh, cut to his specified measurement and used on my evo, it's been about 1500 miles since and it's great.
PoorBoys's Avatar
Ya. Mine is all dinged up too. It is simply unavoidable.
Old Jul 12, 2005 | 09:09 AM
LancerEVOVIIISD's Avatar
You can pull the bumper off and bend the fins back....
Its time consuming but if it really bothers you it is a solution.
Old Jul 12, 2005 | 09:48 AM
pacent's Avatar
Yes, you can use a tweezer or go to your local hardware store and look for a radiator fin rake. Its a thing that looks sorta like a mini comb and you can use it to straighten out your IC fins.
ylee0710
Nov 26, 2016 07:51 AM
Evo Villain
Lancer Aftermarket Forced Induction Tech
Aug 13, 2007 07:28 AM
evo72man
19
Apr 28, 2007 04:57 PM
naucrx
Apr 2, 2005 03:46 PM
evosevengsr
Mar 23, 2004 04:45 AM
