Sparco Evo Racing Shell - Initial Impression
Old Aug 4, 2005 | 09:06 AM
Itsmeeeugene's Avatar
hey can the sidemounts be used the the sliders that sparco sells? or does the sidemounts bolt on directly to the base?
Old Aug 4, 2005 | 09:16 AM
nubby's Avatar
Registered User
You can use sliders with sidemounts, but with the seat base Sparco sells, it puts your seat about 1" higher than stock, and sliders will add another 1/4" to 1/2" to that. I didn't get sliders so I'm not sure on the exact amount.
Old Aug 4, 2005 | 09:50 AM
speedomodel's Avatar
Very nice, nubby. As you know, I had to get my Eclipse specific Sparco brackets completely reworked, too, to get them to work. Sparco seats are definitely worth the money, but their brackets are a ripoff. Let me know when I can check your seat out.
Old Aug 4, 2005 | 09:58 AM
nubby's Avatar
Registered User
Sometime this weekend should work and I'd like to see the Eclipse. Or if you happen to be in the neighborhood of Sublime, stop into work and I'll show off the seat.
I'm sooo happy to have the seat where I want it. I sit a little lower than stock now, which is great and makes the car feel a little less sedan-like.
Old Aug 4, 2005 | 12:23 PM
RallySport Direct's Avatar
Silver Sponsor
Nice to hear you like it.
The problem is that Sparco offers 2 levels of bases. One is way cheap and the other one is a little more expensive. The more expensive brackets are very good qualty and have always fit perfectly in the cars we have installed them in.
The other ones we have never brought in because we do not like selling a inferior product. If you are having a problem installing the seats it is either just the side mounts are flipped the wrong way or you may have the cheaper base.
Ben
Old Aug 4, 2005 | 12:30 PM
nubby's Avatar
Registered User
It's hard to see from the pictures, but my side mounts are now flipped the correct way.
Old Aug 5, 2005 | 09:27 AM
'ringmeister's Avatar
Nubby, the shop that fabbed up your mounts, can they re-produce the mount they made for you or would they need the car in their shop? thanks
Old Aug 5, 2005 | 09:48 AM
nubby's Avatar
Registered User
I'm not sure about that, I had the bracket custom made for a Sparco Evo to fit exactly where I wanted the seat.
If you're really interested, I can get you the contact information for the shop, and if it comes down to it, I'd be happy to drop off my car so they could use my bracket as a template.
I don't know where you're located, but if you have some decent shops around, you might be better off having it fabbed locally.
Old Aug 9, 2005 | 01:46 PM
-Thanks! that's a very generous offer but i wouldn't expect you to go without your car. can you give me contact info for the shop?
Old Aug 9, 2005 | 01:59 PM
nubby's Avatar
Registered User
I'll PM you the contact information. The guy who fabbed the bracket, Mike, said it would only be about 2 hours of labor to build another bracket if he takes the measurements off of my bracket.
The shop is only a couple doors down from where I work, so if Mike needs my bracket to take measurements, I can drop off my car. Won't put me out at all, I can't drive my car when I'm working anyway.
xtnct
May 24, 2019 03:05 PM
Segfault
Evo X How Tos / Installations
19
Apr 23, 2013 05:58 PM
nubby
46
Jul 25, 2007 08:11 PM
peter*g
Nov 29, 2006 04:21 PM
trinydex
Dec 10, 2004 06:32 PM
