Tech Question on Cams
Old Jul 30, 2005 | 12:20 PM
RalliArtEvoVIII's Avatar
Ok my friend goes to a Tech school for mechanics and his teacher is saying if get 272 cams that i will need new valves or else the piston wont have enough clearance and hit the valves. I have never heard of getting valves is a requirement with getting 272 cams.
Old Jul 30, 2005 | 12:24 PM
SlowCar's Avatar
his teacher needs to go back to school
Old Jul 30, 2005 | 12:25 PM
Precision Dyno's Avatar
No he needs to be fired.
Old Jul 30, 2005 | 04:42 PM
HAHAHA this is funny
Old Jul 30, 2005 | 05:18 PM
05-EVO-GSR's Avatar
Your friend needs to find a different teacher.
Old Jul 30, 2005 | 06:17 PM
ok basically what his teacher is saying is that since the compression on the pistons are gonna change that the valves might punch the piston and that i need new valve SPRINGS. I still dont believe this and even if it was true, iknow the evo's stock motor can handle like 8000rpm revs. Can anyone explain this against what his teacher's saying. I've been trying to tell him that the piston's travel isnt gonna change cuz its still gonna be on the same crankshaft.
Old Jul 30, 2005 | 06:27 PM
Mooshu1221's Avatar
does the 272 hks cams change the lift high also, or just duration?
Old Jul 30, 2005 | 09:51 PM
Vivid Racing's Avatar
You will not need to change any other internal engine parts to run the 272 cams.
You can run the 280 cams as well. Some suggest that using a EVO VII set of springs will help, although HKS says it is not required. To answer the last question... Yes the cam changes both lift and duration. The 272 is the duration and the lift is 10.8mm(intake) and 10.2mm(exhaust).
I hope that helped.
Old Aug 1, 2005 | 06:19 AM
availpunk9's Avatar
So how exactly do cams change the compression ratio?
Old Aug 1, 2005 | 07:30 AM
AHHH good question. It affects only dynamic compression ratio along with volumetric efficiency. It gets a little technical...
Old Aug 1, 2005 | 07:32 AM
availpunk9's Avatar
Any good links on that? I would like to read up. I'm at work and am bored :-P
Old Aug 1, 2005 | 08:07 AM
Try this for basics. REAL basics...
http://www.kennedysdynotune.com/Dyna...ion%20Tech.htm
Old Aug 1, 2005 | 08:09 AM
And this..
http://www.davemiranda.com/dmhotrods.htm
Start with these then I can send you some real good articles and in depth testing.
Old Aug 2, 2005 | 06:20 AM
availpunk9's Avatar
good reads explains the needs for adjustible cam gears.
Old Aug 2, 2005 | 06:25 AM
lookEVO's Avatar
good info. I went to a local mechanic college and a lot of people there didnt know ****. they couldnt figure out why my bug was faster than all of there shltbox mustangs and camaros
