Another "what to do" need advice thread (power mods)
Old Jul 31, 2005 | 07:30 PM
sparky's Avatar
In addition to Alky and cat delete get 10.5 and the 272's or 280's.
Old Jul 31, 2005 | 08:24 PM
05-EVO-GSR's Avatar
Originally Posted by justchil
Ok guys I'm having a hard time coming up with the best/most logical next step in my modding adventure. For the next several months I'm going to be on a tight budget so I can get a beater car and start saving for a gt30r/gt35r kit & a built motor.
My current power mods:
Electronics
- SAFC-II
GOOD
- PLX M-500 Wideband
GOOD
- Greddy Turbo Timer
GOOD
- Dynoflash (mail in)
OK
- Greddy Boost Gauge
GOOD
Engine
- Hallman MBC w/Cockpit Controller @20psi
GOOD
- Buschur Racing Intercooler
GOOD
- Buschur Racing Lower IC Piping
GOOD
- Buschur Racing 3" Downpipe
GOOD
- Buschur Racing 3" Catback
GOOD
- Catco 3" High Flow Cat
BAD. DITCH THE CAT.
- HKS 264/264 Cams
OK. UPGRADE TO 272/272
- HKS TP DLI II (Ignition)
GOOD
- Works Drop-In Filter
GOOD
- Kevlar Timing Belt
GOOD
- ARP Headstuds
GOOD
- Odyssey Mini Battery
GOOD
- HKS Ground Kit
GOOD
- Walbro 255 Fuel Pump
GOOD
- JDM MR BOV
GOOD
- Works Drop-in Air Filter
GOOD
I WOULD SUGGEST GETTING SOME BIGGER INJECTORS, 10.5 HOTSIDE. GOOD LUCK.
My current AFR 3rd and part of 4th gear (20psi)
I've been thinking about a few things to start with... First I need to get an Upper IC pipe. Some additional tuning might help on the SAFCII as well. I also need to get some better logging software so I can see timing and what not.
Next is where I'm still fuzzy.. I could get a meth/akly kit so I can run more boost but from what I've read the SAFCII isn't a real good tool for this. I would probably have to spend a good chunk of money for a custom flash.. but I'm not sure if you can run without alky when you have the car flashed for it.
I really only want the extra power doing race situations. I've thought of maybe a 50 shot of NOS but I'm not sure if that would be the best way to go.
I won't go on and on.. but if you're bored please give me some suggestions. I'm really happy with the car but it just needs a little more kick to keep me happy til I can go crazy on the motor.
GOOD LUCK.
Old Aug 1, 2005 | 09:35 AM
justchil's Avatar
Ditching the cat might be a good opetion to start with. I'm still leaning towards getting alky if I can get a custom tune. I really don't want to jump up to 272's just yet.. I just had the 264's installed like a month ago.
I think rather than get a 10.5 hotside I'd upgrade to a TME RS turbo.. but then again I'm on a tight budget so we'll see.
Old Aug 26, 2005 | 09:55 AM
justchil's Avatar
Anyone know if it would be necessary to upgrade injectors with the TME @ stock boost levels? (mods on 1st post)
Or would it be safe to wait until I do alky along with the TME?
Old Aug 26, 2005 | 10:09 AM
Warrtalon's Avatar
Just do the test pipe, 10.5 hotside and alky. The S-AFC can definitely be used to tune in the alky. Talk to Scott at TTP Engineering. That would give you a good 50whp extra without costing a lot or requiring a retune, as long as you know how to use the S-AFC.
Old Aug 26, 2005 | 12:46 PM
justchil's Avatar
That's how I'm leaning.. but the TME sounds better to me right now as long as the funds come through. A little quicker spoolup plus I can sell the stock turbo for a couple hundred.
I'm not really wanting to do alky til next year because the weather is starting to cool down here.
So I should be good on stock injectors with the addition of the test pipe and TME?
