Upgrading to Stage 3 - ???
Old Aug 8, 2005 | 02:35 PM
Nvr2old32's Avatar
Well, my last thread was deleted which was my fault. I posting a racing thread and didn't see the rule up above. Oh well. Learn something everyday.
Anyway, looking to upgrade to Buschur Stage 3. I'll be getting the recommended CAMs but not the intercooler. Instead, I think I'm going with bigger injectors and a fuel pump along with a re-flash.
My question is, will there be a noticeable difference with these three mods along with a re-flash? I hoping so for the $$$$$. (Current Stage 2 / 93 oct / 20psi)
Thanks,
Old Aug 8, 2005 | 02:38 PM
Az3ar's Avatar
Thanks,
why do you want bigger injectors?
Old Aug 8, 2005 | 02:47 PM
Nvr2old32's Avatar
If not injectors, what other mod would you recommend. I guess I thought bigger injectors and fuel pump would be a nice upgrade.
Old Aug 8, 2005 | 03:40 PM
EidolaDream's Avatar
Az3ar is right in asking and hinting that the injectors would be a pointless mod at this point, wait for turbo upgrade.. The walbro 255 works fine with the stockers at the level your at.
Im sorry I dont know buschurs stagesd upgrades but if it were me I would stick with a staged plain, if david says the fmic is the way to go, then get the fmic.. If not I would save the money, not waste it on injectors.
Great setup for street would look something like this
some sort of fuel managment and tuneing
full turboback exhaust
cams/ cam gears (what combo you get is up to you)
fuel pump
there are alot of other things you could throw in that wouldnt really help and could hender performance. Im not sure that a fmic is needed untill you get a larger fmic but if david from bushchur says so.. He knows alot more than I.
honestly I would get with a tuner that you feel you can trust and take there recomindations. For example I put alot of trust into Andrew at dyno4mance. He has always helped me come up with the best setup for "me" not his pocket book.
Old Aug 8, 2005 | 03:48 PM
BoostWhore's Avatar
Get a bigger 02 housing, 10.5 hotside, def think the injectors are pointless
Old Aug 8, 2005 | 06:11 PM
David Buschur's Avatar
The injectors were only added into Stage 4 back in the beginning because we were tuning with an AFC. With an AFC and the factory fuel cut intact we needed the larger injectors to lean out the AFC which in turns raises your fuel cut.
You do NOT need larger injectors if you are sticking with the stock turbo. Don't waste you money on them. The fuel pump is good insurance, but the injectors with the stock turbo for most guys is a waste of money.
Now that only applies if you use the flash, as the re-flash will get rid of the fuel cut.
Thanks guys,
David Buschur
www.buschurracing.com
3000ways
37
Mar 13, 2007 10:13 AM
Nvr2old32
Aug 24, 2005 06:22 PM
EvOJoHnY0312
Jun 21, 2005 04:31 PM
N10S
Midwest Region
Oct 25, 2003 12:40 PM
EVOlution33
Jul 18, 2003 11:36 PM
