More Turbo Timer help!
Old Aug 9, 2005 | 05:58 PM
NIevo's Avatar
I posted alittle while ago about some problems I'm having with my TT keeping my car running. Now I notice that it won't stay running unless I turn the key all the way off really fast with no stopping. Before all I had to do was turn it back one notch to the spot where your radio would stay on but normally your car would turn off. Now if there is any hesitation in turning the key the car just dies. Also the radion stays on now even with the key all the way off and didn't before. I pulled the stearing column cover off and everything looked ok. Please help!
Old Aug 11, 2005 | 12:30 PM
NIevo's Avatar
Can anyone help?
Old Aug 11, 2005 | 12:50 PM
webguy330i's Avatar
So you have (1) ground wire and (1) ebrake wire correct? Sure you got them right?
I didn't the first time around.
Old Aug 11, 2005 | 01:11 PM
NIevo's Avatar
Well the TT was on the car when I baught it but it worked fine for 3 months and just started acting up about a week ago.
Old Aug 11, 2005 | 01:12 PM
webguy330i's Avatar
I guarantee you it's a loose wire, sounds like BOTH wires actually. I'd recommend pulling the dash down and checking it out, and pull the center console pieces out to see how the ebrake wire is attached. Probably failing you right here.
CodyL
Jun 3, 2022 03:59 PM
Bens03vo
Feb 24, 2013 05:41 PM
rcboosted
Feb 8, 2012 08:30 AM
rraulston
AEM EMS
13
Feb 4, 2008 12:22 PM
BBYBruno
Apr 21, 2007 08:06 PM
