Key stuck in the ignition... Please help!
Old Oct 20, 2012 | 08:13 AM
CodyL's Avatar
I was fixing a starting issue my evo vii was having where it would click and click and click then finally turn over, by simply replacing the ignition switch behind the ignition cylinder where your key go's into. After I had replaced that I went to go pull out of my driveway and my steering wheel locked up...? So I pulled back into the driveway and tried turning off my car and my key wont come out of the ignition? So now I'm in a pickle... My key wont come out and my steering wheel is locked... Any suggestions?
Old Oct 20, 2012 | 08:26 AM
Bobrick's Avatar
you probably didn't install something right. take it apart agin and see what is going on.
Old Oct 5, 2017 | 12:10 AM
mr3024446's Avatar
If anyone comes across this - you've got the key shaft 180 degrees out of alignment! There is a pin ontop of the key barrel that you can depress, and pull the whole key assembly out.
In the key barrel there is a tab you compress that removes the steering lock. align the key shaft properly so this is depressed, and insert the key assembly.
Just had this problem fixing my ignition switch..........
Old Jul 24, 2018 | 08:13 AM
ThorArsonSloth's Avatar
I can’t seem to get the ignition cylinder out unless the key is in the lock position(which is my goal anyway)
Old Mar 30, 2019 | 08:55 PM
Acematic91's Avatar
hey did you ever figure out this issue with your key? i just swapped out my ignition switch on my 2005 evo 8 and the steering wheel is locked and my key is stuck in ACC. ive done everything from wiggling key. wiggling steering wheel and key. pushing the key cylinder release pin. unplug battery to reset the car. now im at trying to remove the key cylinder with key attached or remove the whole assembly.
Old Mar 31, 2019 | 03:03 AM
mr3024446's Avatar
Keep trying with the key cylinder release pin to pull the whole assembly out
Old Nov 20, 2021 | 08:54 AM
Vondrunk's Avatar
I just ran into the same issue.. any updates?
Old Jun 3, 2022 | 03:59 PM
Angel Loko's Avatar
where is the tab?
Acematic91
Aug 18, 2019 04:39 PM
timrf79
Nov 15, 2017 10:08 AM
gooov
Jun 13, 2015 04:04 AM
Thahomeboyb
Lancer Troubleshooting
Mar 6, 2014 07:18 PM
bboy_RES
Oct 20, 2012 08:32 AM
