Drove an 05!
Old Aug 15, 2005 | 10:00 AM
EVIL_EVO_VIII's Avatar
Originally Posted by cyberninja
Looking at your sig you should be hitting some really decent power with those mods. IMO i would keep your 03 and build on it. you've already put some serious cash into your car.
Thats what im thinking of. I know i wont get my car payed off for trade and ill get screwed and have a huge payment!!
Old Aug 15, 2005 | 10:12 AM
Warrtalon's Avatar
Originally Posted by MitsubishZ
I bet the '05 models pull just as hard to redline as the previous models do but it seems slightly less because you get a large 20psi pull as compared to 19psi. So in '05 its a taper of 4 psi (20 to 16) and in the previous models its only a 3 psi taper (19 to 16). Could this be a reason?
Not really. The boost peaks higher (20.3psi), holds higher, and ends the taper higher (17+psi). The 05s are stronger up top as evidenced by their ability to hit 105mph stock on pump gas...
Old Aug 15, 2005 | 10:20 AM
So is the 10.5 hotside also a factor for 05 running better?
Old Aug 15, 2005 | 10:31 AM
modvp's Avatar
Wow, are ALL the 05's that much stronger than the 03's..."105mph stock...?" Cool!
Old Aug 15, 2005 | 11:29 AM
Warrtalon's Avatar
It is the BIGGEST factor.
All? Well, they all should be that much stronger, but there are always anomalies where some 03s will be stronger than normal and some 05s will be weaker than normal, but on average, the 05s are about 20whp stronger. I hit 104mph on my first try with the MR, and plenty of others hit 105 on the 05 GSRs.
