Is my hallman mbc defective ??? :confused:
Old Aug 16, 2005 | 02:58 PM
nbpal4000's Avatar
today
i went to my friends house in order to install hallman mbc pro rx.
every connection was right we double checked..but when we turned up the boost it stayed at 0.8 bar(about 11 psi). so we turned once more 1/2 turn. result was same...11 psi.
so we turned it all the way down ( counterclockwise) to see what happen. well the boost was still 11 psi when we tested it. so we put another mbc(cheap one) that my friend had to see if hallman was defective. as soon as we put another mbc and tested it, the boost went up to 1.4 bar...
is my hallman mbc defective?
Old Aug 16, 2005 | 02:59 PM
JeffR116's Avatar
The Hallman is really not sensitive to turning. Turning it a full rotation clockwise is only equivelent to about 1psi change.
Old Aug 16, 2005 | 03:01 PM
nbpal4000's Avatar
but still when i closed it all the way down it still gave me the same result???
Old Aug 16, 2005 | 03:02 PM
NIevo's Avatar
When I installed mine I thought the same thing. I ended up having to turn it quite a few rotations before I even started to notice a change. Try 3 or 4 full rotations and see where you are at.
Jakeg97's Avatar
Originally Posted by nbpal4000
today
possibly. you should return it
or
https://www.evolutionm.net/forums/sh...d.php?t=120185
Old Aug 16, 2005 | 03:04 PM
nbpal4000's Avatar
but before i do more rotations on my hallman, what should happen when i close it all the way down? i thought it shouldnt give boost like 11 psi....
Old Aug 16, 2005 | 03:07 PM
justchil's Avatar
Maybe it was backwords :shrug: Or did you block the bleed hole by any chance?
Old Aug 16, 2005 | 03:08 PM
NIevo's Avatar
I'm not sure why but mine still did. I even called Hallman and they are the ones that said to just keep turning it until I noticed a change.
Old Aug 16, 2005 | 06:25 PM
nbpal4000's Avatar
i think i found what seems to be the problem...when i turned about 6 full rotations i was able to get 14psi so i dont think this mbc is defective
and i just kept turning till the end and the boost i got was 17 psi...
so i am going to change the lighter spring with the heavy one see if it will work...
Old Aug 16, 2005 | 06:28 PM
taenaive's Avatar
you have to use heavy spring! light springs are for honda or low psi boost.
Old Aug 16, 2005 | 07:05 PM
Warrtalon's Avatar
Uh, no, do not spread this misinformation. Hallman didn't make his MBCs designed for hondas. He's been making them for DSMs for years. I have the regular spring and run 21psi daily then 23+ on race gas.
Old Aug 16, 2005 | 07:15 PM
Evoisdream's Avatar
i infact 2 had to use the heavy spring soft one wouldnt go over like 16 o well heavy one has been perfect ever since i think if u pull the soft one out and stretch it a bit it would work probly.....
Old Aug 16, 2005 | 07:32 PM
nbpal4000's Avatar
yep..it was the light spring...
now with the heavy one my evo holds the boost 20 psi till red line
thnks all
Old Aug 16, 2005 | 11:01 PM
gonzo's Avatar
I had to use the hard spring. I thought that was the norm for these MBCs on EVOs.
Old Sep 21, 2005 | 11:42 PM
go2evo's Avatar
just installed tonight, same issue, turned many rotations, still hit 11 psi, at first i thought it was the gauge that is not accurate, cuz i got a 20 bucks gauge, but read 11 psi dead on, soooo glad that i found this thread, tomorrow first thing in the morning, i'll turn it some more to see what happened right before i take off to work. this makes me feel alot more comfortable
cuz even at 11 psi, the car is fast enough...so 10 more psi IS A BIG DIFFERENCE, so i was so confused if it was really running 11 or the gauge is wrong, so now i know. thanks alot of the info guys
