APR Front splitter question
Does the spliiter replace the factory plastic undershield? and to hold the splitter, do i have to drill a hole on the bumper for the holder?
do they fit perfectly with after market FMIC that requires cutting of the factory undertray? or do i have to cut some piece out of the splitter to fit the bigger FMIC? thanx in advance. =)
I would also recommend when installing the splitter to make some sort of reinforced brackets to go behind the bumper where the rods will be attached. I just drilled holes in the bumper and put the screw through and after driving at high rates of speed, I noticed that the rods are pulling the original screw brackets out through the bumper. I hope that makes sense.
