Help from the Mechanically inclined
Old Aug 29, 2005 | 09:27 PM
nefblkevo's Avatar
I'm trying to take apart the manifold, o2 housing and turbo. basicaly 8 bolts all together. Man those mothers are tight. Is WD40 sprayed directly on the bolts a good idea, then just keep torquing until they start to unscrew?
Old Aug 29, 2005 | 09:53 PM
App420's Avatar
Nothing wrong with a spray of wd40 with torqueing it.
Old Aug 29, 2005 | 10:23 PM
white05evoVIII's Avatar
i would personally use PB blaster. you can get it at wal-mart. great stuff. let it sit for about an hour or 2 before you start wrenching. they should come right out. hope this helps.
jeff
Old Aug 29, 2005 | 10:25 PM
Gabriel J's Avatar
Wd40 is not really the best choice for a penetrating oil. Probably the most common solution would be to buy a can of PB Blaster...Works great, I use it at work. Should be at any "auto parts superstore" place. I would also highly recommend sili-kroil, but you would have to special order your own. I used it when I was working as an aviation mechanic in the Coast Guard. -Gabe
http://www.eastwoodco.com/shopping/p...keyword=43381Z
Old Aug 29, 2005 | 10:38 PM
webguy330i's Avatar
Absolutely use PB instead of WD!!
And remember, fast torquing > slow torquing. In other words, use a quick/sharp motion rather than an extendedly long slow motion when trying to unscrew those things.
Old Aug 29, 2005 | 10:58 PM
nefblkevo's Avatar
thanks guys
Old Aug 29, 2005 | 11:37 PM
webguy330i's Avatar
BTW I could not find PB at pep boys, but got it at autozone.
Accept no substitutes!!
Old Aug 29, 2005 | 11:39 PM
byt's Avatar
byt
+1 for PB, I like liquid wrench too
Old Aug 30, 2005 | 12:43 AM
inco9nito99's Avatar
What has helped for me is spraying everything down with PB, turning on the car for a few seconds (10-15seconds), respraying, waiting till everything is cool to touch THEN unscrewing. For sure everything will come off like butter.
Old Aug 30, 2005 | 12:47 AM
jasonn's Avatar
man, if i only read this thread earlier. I almost broke my wrist just taking off the bolts for the exhaust .
Old Aug 30, 2005 | 12:58 AM
nefblkevo's Avatar
I've got a spare manifonld, o2 housing and turbo, so its not in the car. I'm going to pick up the PB tomorrow and work it out.
