Please Break down Alky Injection for me
Old Oct 10, 2005 | 04:54 AM
  #31
yesevo's Avatar
thats cool idea ., but spraying alky at 13psi gives u more power? than 22psi
Old Oct 10, 2005 | 05:30 AM
  #32
4G63>OOOO's Avatar
Doesn't work the way you're thinking.
Think of pump gas as bottled water and alcohol as Red Bull, crack cocaine and crystal meth all rolled into one. Doesn't "make more power" all by itself, but it allows you to do things that wouldn't otherwise be possible with pisstane pump gas.
Old Oct 10, 2005 | 05:49 AM
  #33
kmcconn9's Avatar
Exactly, or just get Al from Dynoflash's new two stage flash and you will be set
...he has tons of information posted up about the alky
Originally Posted by Fourdoor
Real simple.
Set alcohol injection system to start spraying at 22 psi, then set your boost to 20 psi and tune the car on the dyno. After you have a good tune for 20 psi and no alcohol turn up the boost to 24+ PSI. The map (even with a flash) will be tunable in the high boost levels independent of the tune at lower boost levels. Now your high boost area of the map is tuned for use with alcohol.
When you do not want to run alcohol (not sure why you would ever want to not run it.... but you asked) just turn your boost down to 20 psi. No alcohol is sprayed below 22 psi.
Ta Da!
Now, please explain to my why you would not want to run alcohol at any given time? Cheap, works great, and lets you run higher boost with more agressive timeing.
Later,
Keith
Old Oct 10, 2005 | 08:18 AM
  #34
J8dailo's Avatar
im curious...is alky injection good in the long run? and how much higher boost can i run with alky injection?? over stock that is
Old Oct 10, 2005 | 12:17 PM
  #35
inco9nito99's Avatar
I've seen the use of ~30psi on 93octane and/or +5degrees of timing over the max timing curve.
Old Oct 10, 2005 | 01:03 PM
  #36
yesevo's Avatar
it seems like when al tune it,,, he set it to max 25psi...
i wanna be more like at least 28 psi.
higher the boost u make more power? or VS the agressive timing gives u more power?
Old Oct 10, 2005 | 01:59 PM
  #37
Both higher boost and more timing make power. But both have their limits..for boost its turbocharger efficiency, VE, intake charge temps, etc....for timing it's usually ~23degrees BTDC on 4g63 applications figuring a ~8.3:1 compression ratio and a 11.5:1a/f; thereafter you're going to lack power and just induce/exduce unnecc. heat. Also, high boost and high timing= VERY prone to detonation, if not throwing a rod out of your block, so there is a limit and its a fine line depending on various items aforementioned including a/f. Anyyyyyways, personally I prefer boost over timing.
Old Oct 10, 2005 | 03:13 PM
  #38
Nvr2old32's Avatar
I'm going with the Alky kit in November. What I've talked to David about is getting the 20g installed, 660 injectors, and the alky kit. I want to have the kit programed to shoot at 21psi and boost to 25psi. Going to have Al tune it on the dyno for this.
I don't foresee having to fill the tank that often because I don't boost this high a lot. But when I do, hopefully I'll get the rush!
Hopefully, my current 263whp on David's dyno will finally break the 300whp mark. He seems to think so!
Old Oct 10, 2005 | 07:53 PM
  #39
yesevo's Avatar
so can i run max 28 psi with alky kit (using 100%metahnol) on stock turbo?
Old Oct 11, 2005 | 07:49 PM
  #40
yesevo's Avatar
tuner
27
Dec 29, 2006 12:52 PM
djevoawhp
10
Jul 16, 2006 08:43 PM
Warrtalon
72
Jan 24, 2006 04:50 AM
evoego
Jul 21, 2005 04:39 AM
Derek888
20
Feb 26, 2005 11:12 AM
