Evo Storage
Old Sep 5, 2005 | 02:02 PM
evoviiiny's Avatar
Evo Storage
Well i cant take my evo to school so i will be storing it in the garage till next year. I will keep the car on jack stands with a full tank of gas. I will prob. start the car atleast every two weeks and let it run on the jack stands. Does anyone know if i should add dry gas or is that bad for the car? Also is it better if I leave the car in neutral or first. thanks
Old Sep 5, 2005 | 07:42 PM
evoviiiny's Avatar
anyone???
Old Sep 5, 2005 | 07:44 PM
bluetorch's Avatar
idk but im doin the same over the winter
Old Sep 5, 2005 | 07:45 PM
blueo4's Avatar
take it to me I will store it for you
Old Sep 5, 2005 | 07:46 PM
DragNRacing's Avatar
If it were me, I would add Stabil and leave it in neutral. Also make sure to run it up to operating temperature. Also, make sure your coolant is ok for the temps over winter.
Old Sep 5, 2005 | 07:47 PM
Autoxevo's Avatar
Dont let the suspension hang, put the stands under the suspension. Leave it in neutral. As long as the tank is full of good fuel, you shouldn’t need the gas dry.
Old Sep 5, 2005 | 07:55 PM
PunoEvo1337's Avatar
what is the advantage of leaving it on jack stands??? is it a suspension or tire thing?
Old Sep 5, 2005 | 07:56 PM
evoviiiny's Avatar
I dont want my tires to get flat spots.
Old Sep 5, 2005 | 07:59 PM
Autoxevo's Avatar
Ive noticed the Advans flat spot if they sit for any extended length of time.
Old Sep 5, 2005 | 08:00 PM
seems like a good idea... but if you are starting the car every 2 weeks can it not be driven around for a mile or so, to avoid flat spots?
UT_Evo's Avatar
There are special ramps you can buy that are rounded so that the tires won't get flat spots and you won't leave the suspension hanging free. If anyone knows what I'm talking about, maybe they can post a link.
Old Sep 5, 2005 | 08:02 PM
evoviiiny's Avatar
My drive way is on a steep hill, so if there is snow outside i wont get anywhere.
Old Sep 5, 2005 | 08:03 PM
evoviiiny's Avatar
Is it really bad if the suspension hangs?
Old Sep 5, 2005 | 08:04 PM
SevenFour's Avatar
I've let a car sit on the ground and put nothing in the tank...for 10 months....started up 1st try and ran perfectly...
Old Sep 5, 2005 | 08:32 PM
Jakeg97's Avatar
neutral, 1/4 tank, disconnect the battery
