defi control link mounting spots?
Old Sep 9, 2005 | 07:24 PM
Monkey's Avatar
I am about to install my defi guage and I am trying to decide where I want to install the control link. I don't want to put it in the bottom DIN spot. (don't want too many electronics out in the open..burglers). I was thinking about:
in the glove compartment
under the steering wheel column
Where do you have y'all installed?
Old Sep 9, 2005 | 08:21 PM
Jeller's Avatar
I am going to order mine next week and I was thinking the same thing, how about between the seat and the center counsel? Couple people I know have theirs mounted there in other cars, seems to work. Just a thought.
Old Sep 9, 2005 | 08:22 PM
Monkey's Avatar
just with double sided tape?
Old Sep 9, 2005 | 08:49 PM
Joey B's Avatar
Veteran: Air Force
Well, For mine I did a relocation of the radio down to the cubby hole. Then put the control unit right under the radio...modified the cover of course. I'll try and remember to get some pics - but this will hav eto do for now -
https://www.evolutionm.net/forums/sh...9&page=2&pp=15
Go about halfway down....You can kinda see it, but I don't have the modified radio panel on there yet.
Joey
Old Sep 10, 2005 | 07:49 AM
trinydex's Avatar
it fits in the ash tray... try that. with the ash tray removed of course
Old Sep 15, 2005 | 04:48 AM
trinydex's Avatar
ok i think i have to retract my statement... only the apex gauge link module fits in the ash tray.
so jo & joey how did you get that thing to stick there? tape?
Old Sep 15, 2005 | 04:52 AM
kmcconn9's Avatar
it will stick to that location. You just need to use 3m double sided adhesive. It is the kind of adhesive that comes with xm mounting brackets or you can get it in bulk at home depot. It is the adhesive that is used to hold the letters on the front of your house...
simply clean off both surfaces with an alcohol swab, heat up both surfaces, the dash and the controller and the tape (not to the point the tape is bubbling) and then just hold the controller on the surface wth the tape applied for about 45 seconds....it will hold
Old Sep 15, 2005 | 10:52 AM
drtalon's Avatar
I mounted mine on the side of the center console next to the drivers seat. That way it's hidden, but I can still reach it easily while in the car.
Old Sep 15, 2005 | 01:42 PM
trinydex's Avatar
i hate tape.... is there any other way to do it?
Old Sep 15, 2005 | 01:51 PM
webguy330i's Avatar
I put mine in the glovebox. Drilled a nice 1" hole in the side of it for the wires/loom. It's mounted to the left side of the box itself with velcro tape.
It's kinda hard to see but you get the idea:
I plan to remove a 1" wide "strip"of the backside of the glovebox so the control unit slides down inside the glovebox and becomes flush with the top edge.
Old Sep 15, 2005 | 03:36 PM
Monkey's Avatar
That's what I ended up doing as well.
neojin24
Northeast Region
Nov 15, 2010 06:51 AM
MPACT
Dec 1, 2008 10:00 PM
BigBallin
May 16, 2007 04:10 PM
Inn-Tune
Evo 'For Sale' Exterior Styling
37
Nov 9, 2005 07:00 AM
chills
Jun 14, 2005 11:15 PM
