Evo6 tuning questionsssssssssssss
Hi guys, I've just bought myself an evo6 and have the following mods in mind
- hydra ems
- HKS 272 in/ex cams
- HKS cam gears
- ebc boosting at 1.4 bar
- td06-20g turbo
ppl have been telling me that I would need the following to support the above mods:
- gaskets (to lower compression ratio).
- spring valves
but after seeing the dyno section on this web (most of them are evo 7/8 though), I do not see that much (if any) ppl have upgraded their gaskets and spring valve
So my question is, are these 2 parts "a must" if I'm planning to do the step above?
thank you so much!!!
- hydra ems
- HKS cam gears
- td06-20g turbo
- spring valves
I would try http://www.lancerregister.com We never got the Evo 6 in the US. Good luck!
stay away from hydra... its the biggest POS standalone ive seen, a friend of mine put it on his car and no one could effectively tune the car
NOw the guy has an AEM and is definately reaping more benifits
If your running a evo 6 around you should look into Motec or AEM
Black_EVO_MR
Nov 9, 2016 05:10 PM
